Ir para o conteúdo principal
PowerA Enhanced Wireless Controller Motherboard Replacement
Alberto Del Calvo Lopez
Alberto Del Calvo Lopez e 5 outros colaboradores
Última atualização em 16 de ago de 2024
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
This guide will show you how to access and replace the motherboard of your PowerA Enhanced Wireless Controller for Nintendo Switch. Replacing the motherboard is a necessary step for fixing stick drift and power-related issues on your controller. Other motherboard issues are often characterized by unresponsive buttons and your controller failing to immediately turn on.
Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any additional issues. Step 1 of this guide will show you how to access the battery compartment to remove the batteries.
O que você precisa
Ferramentas
  1. PowerA Enhanced Wireless Controller Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller Motherboard Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller Motherboard Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller Motherboard Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller Motherboard Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller Motherboard Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller Motherboard Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
Conclusão
Gear Up For Future Repairs
Shop all
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membros
Autoria de 11 guias
1Comentário do guia
Je cherche un couvercle de batterie pour ma manette switch
Auriez-vous un site où il est possible de s’en procurer un ?
Merci
josselin cornet - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 61
Ao todo: 3,918
