Ir para o conteúdo principal
PowerA Enhanced Wireless Controller L and R buttons Replacement
Ayjah Montgomery
Ayjah Montgomery e 6 outros colaboradores
Última atualização em May 7, 2024
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
If you've been experiencing issues with the functionality of your L and R buttons while using your PowerA Enhanced Wireless Controller for Nintendo Switch, you're not alone. These buttons are crucial to the operation of the controller and can often become less responsive over time due to wear and tear. This guide will walk you through the necessary steps to access and replace or clean these buttons, restoring your controller to peak performance.
This repair will address common issues such as marginal response of the L and R buttons, L and R buttons sticking due to dust or residue build up and/or physical damage on the L and R buttons.
Before beginning the repair process, it's important to remove the batteries from your controller to ensure your safety during the repair and prevent any potential issues with the motherboard. Step 1 of this guide will show you how to access the battery compartment.
O que você precisa
Ferramentas
Exibir mais…
  1. PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
  2. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 2, imagem 1 %32
    • Remove all eight screws using the J0 screwdriver.
  3. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 3, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 3, imagem 2 %32
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
  4. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 4, imagem 3 %32
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
  5. PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement, L and R buttons: passo 5, imagem 3 %32
    • Lift the two white latches using the iFixit opening tool.
    • Lift the white covering off.
  6. PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, imagem 1 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, imagem 2 %32 PowerA Enhanced Wireless Controller L and R buttons Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Squeeze the buttons with rubber tweezers and push them in.
    • Grab it from the back and pull it out.
Conclusão
Uma outra pessoa concluiu este guia.
Ayjah Montgomery
Membro desde: 10/10/19
408 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team S1-G5, Leahy Fall 2019 Membro de USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Membros
Autoria de 11 guias
2Comentários do guia
I need to know how to fix the ZR and the ZL buttons, like a faster response time
Starry Milligan - Responder
im sure this would be really helpful if i knew where i could buy the parts?
arch1e b - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 50
Ao todo: 3,666
