Portege Z830-S8302 Internal Cooling Fan Replacement
Introdução
Vá para o passo 1Before beginning this repair guide, make sure the laptop is powered off and that it is not plugged into any chargers. If laptop was just in use, be cautious of pieces inside the device as they may be hot to touch.
O que você precisa
Flip the laptop over, with screen facing down to reveal bottom panel.
Remove thirteen 1.4mm Phillips #0 screws around the border of the frame.
