Philips HD9252 Touch Screen Motherboard Replacement
Introdução
Ir para o passo 1This guide will lead users through the process of replacing a faulty touch screen. This may be required if the touch screen is unresponsive or does not turn on.
Insert a nylon spudger underneath the top of the device.
Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
Remove the top by lifting it upwards and setting it down.
Hi, I cannot lift the top half because it's blocked by the exhaust vent. Any step that I am missing?
Remove the back panel from the touch screen motherboard by popping the tabs off using the nylon spudger.
