Ir para o conteúdo principal
Parrot FLYPAD Battery Replacement
HUY NGUYEN
HUY NGUYEN e 4 outros colaboradores
Última atualização em August 1, 2024
10 - 20 minutos
Moderado
Introdução
Ir para o passo 1
Bring back to life your Parrot FLYPAD with a brand new battery.
This guide will assist you to correctly dismantle the controller, so that you may easily replace the battery. To prevent any loss of screws, it is important to utilize a magnetic mat placed under the controller.
O que você precisa
Ferramentas
Exibir mais…
  1. Parrot FLYPAD Battery Replacement, Battery: passo 1, imagem 1 %32
    • Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Battery Replacement: passo 2, imagem 1 %32
    • Use a screwdriver to remove the two 0.7 mm screws from the battery cover.
  3. Parrot FLYPAD Battery Replacement: passo 3, imagem 1 %32
    • Separate the plastic cover from battery.
    • Avoid damaging the wires and gently remove the battery from the motherboard.
  4. Parrot FLYPAD Battery Replacement: passo 4, imagem 1 %32
    • Use fingers to gently detach the battery wires from the motherboard.
  5. Parrot FLYPAD Battery Replacement: passo 5, imagem 1 %32
    • Gently attach the wire connection from the new battery to the motherboard. Avoid touching the motherboard directly.
Conclusão
Uma outra pessoa concluiu este guia.
HUY NGUYEN
Membro desde: 04/10/17
376 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S3-G5, Liner Spring 2017 Membro de UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Membros
Autoria de 3 guias
2Comentários do guia
Where did I get a new battery? Can’t find one.
Randy - Responder
Sorry where do I get a new parrot flypad battery. From Randy
Randy - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 13
Ao todo: 1,092
