Ir para o conteúdo principal
Parrot AR.Drone 2.0 Propeller and Gear Replacement
David Hoyt
David Hoyt e 7 outros colaboradores
Última atualização em June 16, 2016
5 minutos
Fácil
Introdução
Ir para o passo 1
Use this guide to replace, propellers, shafts, and gears on a Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
O que você precisa
Ferramentas
Vídeo de Apresentação
  1. Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: passo 1, imagem 1 %32 Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: passo 1, imagem 2 %32
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Propeller and Gear Replacement: passo 2, imagem 1 %32 Parrot AR.Drone 2.0 Propeller and Gear Replacement: passo 2, imagem 2 %32
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
    how do i put the clips back in?
    kuki vier - Responder
    Are you referring to the clips in step three? If so, i highly recommend a hard, flat edged tool like a plastic spudger or flat head screw driver. Push is against the opposite side of the C clip that is opened with roughly the same force you applied to get it off. You have to be really careful that you push it directly horizontal or else you might damage the shaft or risk loosing the clip if it pops off.
    David Hoyt -
  3. Parrot AR.Drone 2.0 Propeller and Gear Replacement: passo 3, imagem 1 %32
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Propeller and Gear Replacement: passo 4, imagem 1 %32 Parrot AR.Drone 2.0 Propeller and Gear Replacement: passo 4, imagem 2 %32 Parrot AR.Drone 2.0 Propeller and Gear Replacement: passo 4, imagem 3 %32
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
Conclusão
4 outras pessoas executaram este guia.
David Hoyt
Membro desde: 04/09/10
4.053 Reputação
Autoria de 41 guias
Equipe
Cal Poly, Team 25-89, Amido Spring 2010 Membro de Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membros
Autoria de 61 guias
1Comentário do guia
any idea how to change the little gear?
Dar BS - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 8,559
