Ir para o conteúdo principal
Oral-B White Pro 1000 Motherboard Replacement
Hannah Parker
Hannah Parker e 3 outros colaboradores
Última atualização em May 27, 2024
20 - 30 minutos
Difícil
Introdução
Ir para o passo 1
Motherboard Replacement guide for Oral-B White Pro 1000 rechargeable electric toothbrush due to faulty operation. This guide illustrates the disassembly of the Oral-B White Pro 1000 electric toothbrush. Use caution not to short the positive (+) and negative (-) terminals when handling the battery. This guide also requires the use of a soldering tool which reaches high temperatures. Refer to this helpful guide for some great soldering and desoldering tips.
O que você precisa
Ferramentas
Exibir mais…
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: passo 2, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 2, imagem 2 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 2, imagem 3 %32
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
    Man sollte die Zahlbürste 5 Minuten in heißes Wasser stellen, damit wird das Plastik weich und man bricht nicht so leicht den Einraster ab.
    pappus - Responder
    You should put the brush in hot water for 5 minutes, so that the plastic becomes soft and you don't break the snap so easily.
    Mike -
    Thanks for tip, was very easy and non-destructive after heating up.
    Tip: Use a big Allen Key (German: Inbus-Schlüssel) as a tool
    David -
    Die Endkappe lässt sich auch gut mit der Ladehalterung aushebeln.
    pappus - Responder
    The end cap can also be easily levered out with the charging bracket
    Mike -
    Beim (fast?) baugleichen Oral-B Pro 2500 Modell ist an der Vorderseite ca. 5mm unterhalb der untersten Signalleuchte eine kleine Öffnung in der Hartplastikhülle, über die nur die Gummibeschichtung läuft (Also von außen nur erfühlbar, nicht sichtbar). Man kann den vorderen Einraster durch das Gummi nach Innen drücken.
    benn_i - Responder
    With the (almost?) Identical Oral-B Pro 2500 model, there is a small opening in the hard plastic shell on the front about 5mm below the lowest signal light, over which only the rubber coating runs (i.e. only palpable, not visible from the outside). You can push the front catch inwards through the rubber.
    Mike -
    the cap actually open from the backside, pivot is on the led side
    Chen Liu - Responder
    The bottom cap comes loose easily with a 45 degree twist using pliers and a piece of cloth for protection.
    Jeroen Razoux Schultz - Responder
  3. Oral-B White Pro 1000 Motherboard Replacement: passo 3, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 3, imagem 2 %32
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
    If the green charge led quit flashing, check the hair fine coil connections to the PC board. One of mine was broken and soldering it back was the fix. Probably broke from vibration
    Paul Washburn - Responder
  4. Oral-B White Pro 1000 Motherboard Replacement: passo 4, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 4, imagem 2 %32
    • Use flat head screwdriver to remove power button pressure plate.
    On mine, the head end of the pressure plate has a ‘wing’ on each side that can be pushed in to release from the other metal enclosure that has not been removed yet.
    scottbernardis - Responder
  5. Oral-B White Pro 1000 Motherboard Replacement: passo 5, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 5, imagem 2 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 5, imagem 3 %32
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
    Before going further, check these two connections for continuity. With my toothbrush one of the two coil wires was not making a good connection and therefor not charging the battery. Easy fix if that’s your problem.
    Stefan Ruiter - Responder
    @ifixit: Second picture is wrong, since it shows soldering the motor and not the coil! But you get the idea :-)
    David - Responder
  6. Oral-B White Pro 1000 Motherboard Replacement: passo 6, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 6, imagem 2 %32
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
    pics too small. show after housing off and not how to get there. why even go to this hell and not have replaceable batteries like a remote or flashlight? this is made this hard just so you buy another one.
    Dave Sprague - Responder
  7. Oral-B White Pro 1000 Motherboard Replacement: passo 7, imagem 1 %32 Oral-B White Pro 1000 Motherboard Replacement: passo 7, imagem 2 %32
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
    Man kann den Akku durch eine Standard AA Zelle mit Lötfahnen austauschen. Diese sind preiswerter und erhöhen die Kapazität. In diesem Fall muss man nur die Plastik-Abstandshalter im Akkuhalter mit einem Cutter stutzen.
    pappus - Responder
    The battery is not soldered it is spot welded
    Mike - Responder
Conclusão
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
3 outras pessoas executaram este guia.
Hannah Parker
Membro desde: 11/08/17
221 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S5-G4, Baechle Fall 2017 Membro de IUPUI, Team S5-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G4
3 Membros
Autoria de 8 guias
1Comentário do guia
Motor are brushless?
joseferreira_ms - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 26
Últimos 30 dias: 71
Ao todo: 3,296
