Ir para o conteúdo principal
Nokia G42 5G Battery Replacement
Manuel Haeussermann
Manuel Haeussermann e 6 outros colaboradores
Última atualização em November 13, 2024
30 minutos - 1 hora
Moderado
Guia em destaque
Guia OEM
Introdução
Ir para o passo 1
Use this guide to replace the battery in your Nokia G42 5G.
For your safety, turn on your phone and allow the battery to discharge below 25% before starting this procedure. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery looks puffy or swollen, take extra precautions.
Don't reuse the battery after it's been removed, as doing so is a potential safety hazard. Replace it with a new battery.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Nokia G42 5G Battery Replacement, Eject the SIM card tray: passo 1, imagem 1 %32 Nokia G42 5G Battery Replacement, Eject the SIM card tray: passo 1, imagem 2 %32 Nokia G42 5G Battery Replacement, Eject the SIM card tray: passo 1, imagem 3 %32
    • Power down your phone and unplug any cables.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the upper left edge of the phone.
    • Press firmly to eject the tray.
  2. Nokia G42 5G Battery Replacement, Remove the SIM card tray: passo 2, imagem 1 %32 Nokia G42 5G Battery Replacement, Remove the SIM card tray: passo 2, imagem 2 %32 Nokia G42 5G Battery Replacement, Remove the SIM card tray: passo 2, imagem 3 %32
    • Remove the SIM card tray.
    • When installing either a SIM card or a microSD card, make sure they're in the correct orientation and sitting completely flush with the edges of the tray before reinserting the tray into the phone.
  3. Nokia G42 5G Battery Replacement, Insert an opening pick: passo 3, imagem 1 %32 Nokia G42 5G Battery Replacement, Insert an opening pick: passo 3, imagem 2 %32 Nokia G42 5G Battery Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • The back cover is held in place by plastic clips.
    • Insert an opening pick under the small notch in the SIM card tray slot.
  4. Nokia G42 5G Battery Replacement, Release the plastic clips: passo 4, imagem 1 %32 Nokia G42 5G Battery Replacement, Release the plastic clips: passo 4, imagem 2 %32 Nokia G42 5G Battery Replacement, Release the plastic clips: passo 4, imagem 3 %32
    • Position the opening pick at a steep downward angle between the back cover and the screen assembly.
    • Slide the opening pick down the left edge of the phone to release the plastic clips.
  5. Nokia G42 5G Battery Replacement: passo 5, imagem 1 %32 Nokia G42 5G Battery Replacement: passo 5, imagem 2 %32 Nokia G42 5G Battery Replacement: passo 5, imagem 3 %32
    • Turn the opening pick around the corner and continue to slide it along the bottom edge to release the plastic clips.
  6. Nokia G42 5G Battery Replacement: passo 6, imagem 1 %32 Nokia G42 5G Battery Replacement: passo 6, imagem 2 %32 Nokia G42 5G Battery Replacement: passo 6, imagem 3 %32
    • Slide the opening pick up the right edge to continue releasing the plastic clips.
  7. Nokia G42 5G Battery Replacement: passo 7, imagem 1 %32 Nokia G42 5G Battery Replacement: passo 7, imagem 2 %32 Nokia G42 5G Battery Replacement: passo 7, imagem 3 %32
    • Slide the opening pick along the top edge to release the remaining plastic clips.
    • Don't try to fully remove the back cover just yet, as it's still connected with a cable.
  8. Nokia G42 5G Battery Replacement, Flip open the back cover: passo 8, imagem 1 %32 Nokia G42 5G Battery Replacement, Flip open the back cover: passo 8, imagem 2 %32 Nokia G42 5G Battery Replacement, Flip open the back cover: passo 8, imagem 3 %32
    • With the phone laying screen-side down, carefully lift the right edge of the back cover, opening it like a book.
    • Take care not to strain or tear the attached fingerprint reader cable during this procedure.
    • Lay the back cover next to the phone.
  9. Nokia G42 5G Battery Replacement, Unfasten the fingerprint reader bracket: passo 9, imagem 1 %32
    • Use a Phillips screwdriver to remove the 3.8 mm‑long screw securing the fingerprint reader bracket.
  10. Nokia G42 5G Battery Replacement, Remove the fingerprint reader bracket: passo 10, imagem 1 %32 Nokia G42 5G Battery Replacement, Remove the fingerprint reader bracket: passo 10, imagem 2 %32 Nokia G42 5G Battery Replacement, Remove the fingerprint reader bracket: passo 10, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers or your fingers to remove the fingerprint reader bracket.
    • Take care not to puncture the battery with sharp tools—a punctured or creased battery may leak dangerous chemicals or cause a fire.
    • During reassembly, make sure to slide the bracket's edge back into its slot under the motherboard cover.
  11. Nokia G42 5G Battery Replacement, Disconnect the fingerprint reader: passo 11, imagem 1 %32 Nokia G42 5G Battery Replacement, Disconnect the fingerprint reader: passo 11, imagem 2 %32 Nokia G42 5G Battery Replacement, Disconnect the fingerprint reader: passo 11, imagem 3 %32
    • Use the pointed end of a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
    • Remove the back cover.
  12. Nokia G42 5G Battery Replacement, Unfasten the motherboard cover: passo 12, imagem 1 %32
    • A white sticker might cover one of the top screws. Pierce through it with the tip of your screwdriver or use a pair of tweezers to remove it.
    • Use a Phillips screwdriver to remove the ten 3.8 mm-long screws securing the motherboard cover.
  13. Nokia G42 5G Battery Replacement, Pry up the motherboard cover: passo 13, imagem 1 %32 Nokia G42 5G Battery Replacement, Pry up the motherboard cover: passo 13, imagem 2 %32 Nokia G42 5G Battery Replacement, Pry up the motherboard cover: passo 13, imagem 3 %32
    • The motherboard cover is further held in place by plastic clips.
    • Insert an opening pick under the right edge of the motherboard cover.
    • Twist the opening pick to release the plastic clips.
    • During reassembly, clip in the motherboard cover on the top left first.
  14. Nokia G42 5G Battery Replacement, Remove the motherboard cover: passo 14, imagem 1 %32 Nokia G42 5G Battery Replacement, Remove the motherboard cover: passo 14, imagem 2 %32 Nokia G42 5G Battery Replacement, Remove the motherboard cover: passo 14, imagem 3 %32
    • Use a pair of tweezers or your fingers to remove the motherboard cover.
  15. Nokia G42 5G Battery Replacement, Disconnect the battery cable: passo 15, imagem 1 %32 Nokia G42 5G Battery Replacement, Disconnect the battery cable: passo 15, imagem 2 %32
    • Use the flat end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  16. Nokia G42 5G Battery Replacement, Loosen the battery tabs: passo 16, imagem 1 %32 Nokia G42 5G Battery Replacement, Loosen the battery tabs: passo 16, imagem 2 %32
    • Be extra careful to not puncture, bend, or deform the battery during the next few steps—a damaged battery may leak dangerous chemicals or cause a fire.
    • Use your fingers to peel the two outer adhesive tabs off of the battery.
  17. Nokia G42 5G Battery Replacement, Lift out the battery: passo 17, imagem 1 %32 Nokia G42 5G Battery Replacement, Lift out the battery: passo 17, imagem 2 %32 Nokia G42 5G Battery Replacement, Lift out the battery: passo 17, imagem 3 %32
    • The battery in the Nokia G42 5G is secured to the frame with adhesive. Pull tabs are provided to separate the adhesive and remove the battery.
    • Use your fingers to peel the center green pull tab off of the battery.
    • Using one hand to hold the phone steady, use your other hand to slowly and steadily lift the center green pull tab up to separate the adhesive securing the battery underneath.
    • If the green pull tab rips, use the outer clear tabs instead.
    • If you have any difficulties with stubborn battery adhesive, you can contact Nokia's phones support.
  18. Nokia G42 5G Battery Replacement, Remove the battery: passo 18, imagem 1 %32 Nokia G42 5G Battery Replacement, Remove the battery: passo 18, imagem 2 %32 Nokia G42 5G Battery Replacement, Remove the battery: passo 18, imagem 3 %32
    • Peel the battery off of the adhesive film and remove it.
    • Don't reinstall a damaged or deformed battery, as doing so is a potential safety hazard. Replace it with a new battery.
  19. Nokia G42 5G Battery Replacement, Remove the battery adhesive film: passo 19, imagem 1 %32 Nokia G42 5G Battery Replacement, Remove the battery adhesive film: passo 19, imagem 2 %32 Nokia G42 5G Battery Replacement, Remove the battery adhesive film: passo 19, imagem 3 %32
    • Grab the bottom right edge of the leftover adhesive film and pull it towards the top of the phone with steady force to remove it.
    • To install a replacement battery:
    • Apply isopropyl alcohol (>90%) to the old adhesive and use the flat end of a spudger to scrape it off.
    • Remove the clear liner on the pre-cut battery adhesive and apply the sticky section to the battery well. Remove the opaque liner before continuing reassembly.
    • Remove the battery adhesive film from its liners and apply it to the battery.
    • Align the bottom edge of the battery (the edge without adhesive) with the bottom edge of the recess.
    • Lower the battery down and press firmly to secure it in place.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
3 outras pessoas executaram este guia.
Manuel Haeussermann
Membro desde: 07/13/22
19.496 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.545 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 57
Últimos 30 dias: 250
Ao todo: 9,534
