Ir para o conteúdo principal
Nintendo Game Boy Advance SP Motherboard Replacement
DJ Pantone
DJ Pantone e 9 outros colaboradores
Última atualização em September 12, 2023
10 minutos
Moderado
Introdução
Ir para o passo 1
The motherboard is the green electrical plate that runs the device. Without the motherboard, the device will not function. This is why we advise against removing the motherboard from the system. Any accidental tug can tear the golden ribbon cable. If that happens you now have more problems then you came here with in the first place!
O que você precisa
Ferramentas
Exibir mais…
  1. Nintendo Game Boy Advance SP Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Nintendo Game Boy Advance SP Motherboard Replacement: passo 2, imagem 1 %32
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Nintendo Game Boy Advance SP Motherboard Replacement: passo 3, imagem 1 %32
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
  4. Nintendo Game Boy Advance SP Motherboard Replacement, Back Cover: passo 4, imagem 1 %32 Nintendo Game Boy Advance SP Motherboard Replacement, Back Cover: passo 4, imagem 2 %32
    • Remove four 6.5 mm screws from the corners of the back cover using a tri-point Y00 screwdriver.
    • Remove two 4.6mm screws from the top-center and bottom-center of the device using a tri-point Y00 screwdriver.
  5. Nintendo Game Boy Advance SP Motherboard Replacement: passo 5, imagem 1 %32
    • Lift the back cover off of the device.
    • Potential for device damage: These inner components are vulnerable to static electricity. Exercise caution when handling these next steps to prevent damaging the device.
    • Look out for the power switch that can fall out when taking the back cover off.
  6. Nintendo Game Boy Advance SP Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the three Phillips #00 4 mm long screws that hold the motherboard to the button panel.
  7. Nintendo Game Boy Advance SP Motherboard Replacement: passo 7, imagem 1 %32
    • Be careful not to tear the ribbon cable that's connected to the screen. If you tear it, games will not appear on the device's screen!
    • Flip the motherboard up and rest it on the other half of the device, so that the back of the buttons are visible as seen in the picture.
Conclusão
26 outras pessoas executaram este guia.
DJ Pantone
Membro desde: 01/11/13
1.938 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 17-22, Forte Winter 2013 Membro de Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Membros
Autoria de 41 guias
4 comentários
I just bought one at a garage sale. Everything works fine, but the screen does not display properly. when you turn the unit on, all you get is vertical lines on the screen. They are random each time you turn it on. Is the ribbon ripped? If so, can you get a new one??? If so - where?
Brian - Responder
picked up Gameboy advanced sp 101 model when you go to charge it the light comes on but then shuts off so I thought maybe its either the battery or a fuse on the motherboard how can I change that or fix it
jourdanjoseph - Responder
I think this would be a good idea, one day i will have a new GBA SP LCD screen and then, disassemble it and replace the screen
Santi12008 - Responder
I dropped it once , now half of the games do not run, what should I do?
Sarthak sibou - Responder
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 66
Últimos 30 dias: 362
Ao todo: 43,469
