Nintendo DS Main Circuit Board Replacement
Introdução
Ir para o passo 1This is a guide that teaches how to replace a Nintendo DS motherboard also known as a circuit board.
The Nintendo DS is a video game console released by Nintendo proposing two screens working in tandem with wireless connectivity, and an integrated microphone.
The main circuit board holds and makes all communication between components of the device possible. Therefore, whenever the communication between the functioning components takes longer than expected or there is no communication, replacing the motherboard is a necessity.
The removal of the main motherboard of the DS is essential to access the screens and to replace other imperatives.
The replacement could be done in 10 simple steps.
O que você precisa
Remove the cartridge from the console.
Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
Remove the battery door.
Remove the seven 6.4mm Y00 screws located on the back.
I am currently doing this after my DS broke, and I just cannot get the screws out. My dad thinks they are too big, and I see they are stripped. Am I screwed?
Hi @theoskar, Sorry to hear you're having a hard time removing the screws from your DS. We put together a quick guide and video with a few tips you can try here. Stripped screws often happen when the tool doesn’t quite match the job, but the good news is that they’re easy to prevent with the right technique. If you haven’t already, take a look at our guide on screwdriver technique. We hope this helps!
With your hands, pry the back panel off the main case.
Separate the back from the front, and set it aside.
If some of your screws spin free but can’t be removed, it maybe that the screw posts have separated from the shell.
This makes separating the back panel more difficult, but it will still work.
The plastic used for the original silver nds may be the most prone to the UV damage that causes the plastic to become brittle.
Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
Unlock the two large ribbon cables by moving the black clip up.
Carefully pull the ribbon cables down and out with your fingers.
Benutze für die nächsten Schritte besser einen Spudger und keine Pinzette,
sonst läufst du Gefahr eines der Kabel oder die Platine selbst zu beschädigen.
Better use a Spudger, not a Tweezer for the next Steps.
That minimize the risk to demolish one of the wires or the mainboard himself.
That’s what i did but it didn’t work
Are you able to flip open the black latch, or is that the part that's stuck?
Gena FM -
Hi Theo, you might find this guide on how to recognize and disconnect cable connectors helpful.
Ferramenta utilizada neste passo:Tweezers$4.99
Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
Slide the locks for the small ribbon cables down to the side, and remove the cables.
Does anyone know where I can get a new connector for the P6 connector? I can only find them for the ds lite
22 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
