Ninja Mega Kitchen System BL770 LED Light Replacement
Introdução
Ir para o passo 1If you notice the LED lights on your device are continuously blinking or not working at all, this step-by-step guide will show you how to replace them individually, or all together. For soldering help, follow the How to Solder and Desolder Connections guide.
O que você precisa
Ferramentas
Exibir mais…
On the circuit board, locate the LED light you wish to replace.
On the bottom of the board, each LED is designated with a small triangle with a line at one tip and a label of LED1, LED2, etc.
