Ir para o conteúdo principal
Milwaukee Impact Wrench 9070-20 Power Cord Replacement
Yuna Choi
Yuna Choi e 4 outros colaboradores
Última atualização em December 11, 2019
10 - 15 minutos
Fácil
Introdução
Ir para o passo 1
If the device is not powering on, the most common cause is from the power cord. Wrapping the cord around the device when stored or using the device from a far distance from where it is plugged may cause the cord issue. This impact wrench operates with a connected power cord. In most cases of having a faulty power issue, it can be easily fixed with replacing the cord line.
But a good news is that the power cord is easy to replace and find from any store. This guide will help you to go through the replacement procedures.
O que você precisa
Ferramentas
  1. Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: passo 1, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: passo 1, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Power Cord Replacement, Power Cord: passo 1, imagem 3 %32
    • Ensure that the device is unplugged from any power source to avoid electrical shock.
    • Flip the device and remove four 18mm screws using the T20 Torx screwdriver.
    • Remove the four 14mm screws using the same screwdriver.
  2. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 2, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 2, imagem 2 %32 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 2, imagem 3 %32
    • Hold the device so the gray part faces directly towards you.
    • Remove the four screws on the sides using the T20 Torx screwdriver.
    • After removing all screws, use a small plastic pry bar to slide the gearbox assembly forward slightly.
  3. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 3, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 3, imagem 2 %32
    • Gently remove the upper clam shell from the device.
    • Lift a black colored power cord from its mount at the bottom of the device, so it can move freely.
  4. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 4, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 4, imagem 2 %32
    • Disconnect the brown field winding wire from the white ac power cord wire.
  5. Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 5, imagem 1 %32 Milwaukee Impact Wrench 9070-20 Power Cord Replacement: passo 5, imagem 2 %32
    • Disconnect the black ac power wire from the connector on the bottom of the forward / reverse switch.
    • Remove the AC power cord and replace it with a new one.
Conclusão
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 386
