Eixo de mandril de caneta de 7 mm
2 respostas 5 pontos |
minha parafusadeira parou e não liga, sem sinal de queimado. |
3 respostas 3 pontos |
Como retirar o mandril da furadeira... |
1 resposta 1 pontos |
gatilho de acionamento quando aperta funciona e do nada para |
3 respostas 1 pontos |
Minha parafusadeira Bosch parou de funcionar |
Peças
- FixHub Power Station Replacement Main Board Support
- FixHub Soldering Iron Replacement Power Switch Cover
- FixHub Soldering Iron Replacement End Cap
- FixHub Soldering Iron Replacement Enclosure
- FixHub Soldering Iron Replacement Grip
- FixHub Power Station Replacement Button
- FixHub Power Station Replacement Battery Cover
- FixHub Power Station Replacement Tool Mount
Ferramentas
- FixHub Soldering Iron Point Tip
- FixHub Soldering Iron Heat Insert Tip
- iFixit Safety Glasses
- FixHub Soldering Iron Knife 1.4 Tip
- FixHub Soldering Iron Wedge 1.5 Tip
- Cut-Resistant ESD Gloves
- FixHub Soldering Iron Angle Cone Tip
- FixHub Soldering Iron Wedge 4.0 Tip
- FixHub Soldering Iron Cone Tip
- FixHub Soldering Iron Bevel 2.6 Tip
- FixHub Soldering Iron Knife 2.5 Tip
- FixHub Soldering Iron Bevel 1.5 Tip
- FixHub Soldering Iron Angle Knife Tip
- FixHub Soldering Iron Bent Cone Tip
- FixHub Soldering Iron Bevel Cup 1.5 Tip
- FixHub Soldering Iron Bevel Cup 2.6 Tip
Modelos
AS52500468, AS5250BZ853, AS5517-5068, AS55527803, AS57336600, AS5733Z4477, AS57506438, AS57506636, AS7551G7606, CGRAXM230U, GP1, GRAS760U, GRAX230U, GRAX7600, GRAX760U, GRAX760US, GRAX761U, GRAX76U, GRAX880US, GRAX970U Exibir 43 mais
GRAXAM230U, GRAXM151US, GRAXM2300, GRAXM230U, GRAXM231U, GRAXM23OU, GRAXM240U, GRAXM241U, GRAXM341U, GRCVL510U, GRD200U, GRD200US, GRD201US, GRD22US, GRD30US, GRD31US, GRD70US, GRD90US, GRD91US, GRD9OUS, GRDL815U, GRDLV310U, GRDM70U, GRDV500U, GRDV500US, GRDV800US, GRDVL500U, GRDVL500US, GRDVM76U, GRDX300US, GRDX75US, GRDX95US, GRSXM240, GRSXM240U, GRSXM245U, GRSXM340U, GRSXM540U, GRSXM740U, GRSXM745U, GRSXM750US, LXSA9020, PANORAMA, PV1D
Informações gerais
Ferramentas elétricas são essenciais tanto em projetos profissionais quanto domésticos, oferecendo uma ampla faixa de funcionalidades para tornar mais fácil o trabalho manual em obras, consertos e manutenções. Essas ferramentas são produzidas pelos mais diversos fabricantes, nos EUA temos as proeminentes marcas DeWalt, Milwaukee e Makita. No Brasil, as maiores marcas de ferramentas elétricas são: Schulz, Vonder e Einhell.
Ao longo dos anos, essas marcas passaram por fusões, aquisições e avanços tecnológicos até conseguirem fornecer ferramentas duráveis e eficientes. Por exemplo, a Milwaukee é conhecida pela tecnologia REDLITHIUM das suas baterias.
A fabricação de ferramentas elétricas frequentemente é realizado em várias unidades ao redor do globo, como na China, Alemanha, Japão e os EUA, que acolhe importantes unidades de produção.
Identificação
A identificação de uma ferramenta elétrica implica geralmente localizar o número do modelo, que se encontra geralmente em uma etiqueta afixada na ferramenta ou gravado no estojo da ferramenta. Modelos muito vendidos da DeWalt são a DCD771 (furadeira elétrica ou berbequim elétrico) e o DCF885 (chave de impacto), enquanto os modelos mais vendidos da Milwaukee são o 2804-20 (martelete perfurador) e o 2853-20 (chave de impacto).
Marcas diferentes costumam ter esquemas de cores e elementos de design únicos que os diferencia. Por exemplo:
- DeWalt: Esquema de cores amarelo e preto.
- Milwaukee: Esquema de cores vermelho e preto.
- Makita: Esquema de cores azul petróleo e preto.
- Ryobi: Esquema de cores verde lima e preto.
O número de modelo é crucial para se obter informações de reparo acuradas e peças de reposição corretas. O número do modelo encontra-se próximo ao compartimento da bateria, no invólucro do motor ou no punho da ferramenta.
Diagnóstico
Os problemas mais comuns encontrados em ferramentas elétricas são problemas de bateria, disfunções do motor e o desgaste e a fadiga mecânica. Para problemas relacionados à bateria, é crucial garantir que a bateria esteja completamente carregada e corretamente encaixada. Problemas com o motor podem exigir uma verificação das escovas do motor e das conexões elétricas. Problemas mecânicos implicam muitas vezes a verificação de engrenagens, mancais e outras peças móveis para averiguar se há desgaste, ou se a lubrificação e o alinhamento estão corretos.
Uma manutenção consistente pode resolver ou evitar muitas falhas comuns em ferramentas elétricas.
Informações adicionais
Um agradecimento especial a esses tradutores:
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
