Ir para o conteúdo principal
Milwaukee Circular Saw 263020 B57A 2008 Upper Gearcase Replacement
Ahmed Altawami
Ahmed Altawami e 4 outros colaboradores
Última atualização em December 19, 2023
5 minutos
Fácil
When using the Milwaukee 2630-20, the gearcase acts as a shield, protecting you from flying debris and wood. Damage to the upper gearcase can potentially cause a risk in performance problems, damage with prolonged use, and a risk to the safety of the user. If there is damage or chipping to the upper gearcase with exposure to the blade, please refer to this guide to replace the upper gearcase.
O que você precisa
  1. Milwaukee Circular Saw 263020 B57A 2008 Upper Gearcase Replacement, Upper Gearcase: passo 1, imagem 1 %32 Milwaukee Circular Saw 263020 B57A 2008 Upper Gearcase Replacement, Upper Gearcase: passo 1, imagem 2 %32 Milwaukee Circular Saw 263020 B57A 2008 Upper Gearcase Replacement, Upper Gearcase: passo 1, imagem 3 %32
    • Remove three 8 mm screws from the top of the upper gearcase using a Torx T6 screwdriver.
  2. Milwaukee Circular Saw 263020 B57A 2008 Upper Gearcase Replacement: passo 2, imagem 1 %32 Milwaukee Circular Saw 263020 B57A 2008 Upper Gearcase Replacement: passo 2, imagem 2 %32
    • Carefully remove the upper gearcase with your hand and replace it with a new one.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 57
