Magic Bullet NutriBullet Pro Rubber Gasket Replacement
Introdução
Ir para o passo 1This guide will demonstrate how to replace a damaged rubber gasket on the blender blade lid of your cup. The rubber gasket is responsible for sealing the cup from leaking. Other possible problems can be found in our Troubleshooting Guide.
O que você precisa
Ferramentas
Ferramenta utilizada neste passo:Tweezers$4.99
Use tweezers to peel back the rubber gasket that surrounds the inner ring of the lid.
His Step 3 is to "Reverse the process" which is NOT helpful at all. I think I would need about 4 hands to keep the gasket in the groove while turning the base to complete the circle. This was not usefull!
