Ir para o conteúdo principal
Magic Bullet MB1001B Activator Replacement
Aubree Duran
Aubree Duran e 4 outros colaboradores
Última atualização em 9 de jan de 2024
20 - 30 minutos
Moderado
Introdução
Ir para o passo 1
Are you having trouble getting your Magic Bullet to turn on? Are the plastic activator tabs on your Magic Bullet broken off? This guide will help you replace the activators.
O que você precisa
Ferramentas
Exibir mais…
  1. Magic Bullet MB1001B Activator Replacement, Base Gear: passo 1, imagem 1 %32 Magic Bullet MB1001B Activator Replacement, Base Gear: passo 1, imagem 2 %32 Magic Bullet MB1001B Activator Replacement, Base Gear: passo 1, imagem 3 %32
    • Use pliers to grip the gear inside of the top of the device.
    • You may have to remove a sticker that is covering the slit at the center of the bottom before completing the next step.
    • Insert a flathead screwdriver into the slit at the bottom of the device while still holding the pliers in place gripped on the gear.
    • Lay the device on its side. Holding the screwdriver stationary to hold the bottom side in place, use the pliers to unscrew the gear by turning the pliers CLOCKWISE.
    Can you replace the base gear in a Mini Bullet? I am having a hard time unscrewing it.
    Margaret Bellanger - Responder
  2. Magic Bullet MB1001B Activator Replacement, Casing: passo 2, imagem 1 %32
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
  3. Magic Bullet MB1001B Activator Replacement: passo 3, imagem 1 %32
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
  4. Magic Bullet MB1001B Activator Replacement: passo 4, imagem 1 %32
    • Remove the black base plate.
  5. Magic Bullet MB1001B Activator Replacement: passo 5, imagem 1 %32
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
  6. Magic Bullet MB1001B Activator Replacement: passo 6, imagem 1 %32
    • Remove the white plastic cable guide.
  7. Magic Bullet MB1001B Activator Replacement: passo 7, imagem 1 %32
    • Remove the three 11.0 mm Phillips head screws surrounding the white fan blade on the base using the Phillips #1 screwdriver.
  8. Magic Bullet MB1001B Activator Replacement: passo 8, imagem 1 %32
    • Remove the black base.
  9. Magic Bullet MB1001B Activator Replacement: passo 9, imagem 1 %32
    • Remove the three white rubber spacers with the spudger.
    White rubber spacer is broke from where to get one in colombon
    anonymous 1603 - Responder
  10. Magic Bullet MB1001B Activator Replacement: passo 10, imagem 1 %32
    • Remove the three 11.0 mm Phillips head screws using the Phillips #1 screwdriver.
    How is called the cover held by the 3 screws? Can be bought somewhere?
    Nicolas All - Responder
    will U give me feedback? If U have a part # will be great!
    Mine is broken, the rest is perfect! Thanks!
  11. Magic Bullet MB1001B Activator Replacement: passo 11, imagem 1 %32
    • Remove the motor.
  12. Magic Bullet MB1001B Activator Replacement, Activator: passo 12, imagem 1 %32 Magic Bullet MB1001B Activator Replacement, Activator: passo 12, imagem 2 %32
    • Wedge a flathead screwdriver in between the casing and white plastic activator.
    • Pry the white plastic activators from the casing as needed.
    Do you know of anywhere to just buy the activator part for this machine? Thanks
    Izzi - Responder
    Where can I buy the “white plastic activators”?
    Erick Mata-Montero - Responder
Conclusão
3 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Aubree Duran
Membro desde: 10/06/15
387 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-13, Maness Fall 2015 Membro de Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Membros
Autoria de 8 guias
4Comentários do guia
You gotta be kidding me?
marcomolinero72 - Responder
Right. Steps on how to fix their faulty machine. And worse. Selling you the tools to do it for only 29.99!
Del - Responder
Where would you get replacement activators or spring beneath these? How much would that cost?
Spartan 1293 - Responder
Oh, my gosh! I’ll just throw this thing away and use my blender!
txberta - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Ao todo: 9,444
