Ir para o conteúdo principal
Lenovo Thinkpad T450 SSD Replacement
Justin Ogihara
Justin Ogihara e um outro colaborador
Última atualização em April 12, 2025
10 - 25 minutos
Moderado
Introdução
Ir para o passo 1
The solid-state drive (or SSD) is a storage device used to store data. SSDs are much faster than the traditional hard-disc drives (HDD) due to their physical nature. Unlike the standard HDD, an SSD does not have a physical spinning disc in the component. Current estimates show that SSDs may reach a lifespan of 10 years, but the average lifespan of a SSD is shorter.
If your Lenovo ThinkPad T450 laptop is not properly loading files or is slow to load, it may be time to replace the SSD. Follow these instructions to replace the SSD in your device.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Lenovo Thinkpad T450 SSD Replacement, External Battery: passo 1, imagem 1 %32 Lenovo Thinkpad T450 SSD Replacement, External Battery: passo 1, imagem 2 %32 Lenovo Thinkpad T450 SSD Replacement, External Battery: passo 1, imagem 3 %32
    • Using your hands, slide the two locking tabs away from each other to release the battery.
    • Slide the battery up and out of the device.
  2. Lenovo Thinkpad T450 SSD Replacement, Back Cover: passo 2, imagem 1 %32
    • Using the JIS #00 screwdriver, unscrew seven screws from the back cover.
    • These screws are not removable and will remain in the back cover.
    • Use the JIS #00 screwdriver to remove the single 2.8 mm screw from the back cover.
  3. Lenovo Thinkpad T450 SSD Replacement: passo 3, imagem 1 %32 Lenovo Thinkpad T450 SSD Replacement: passo 3, imagem 2 %32 Lenovo Thinkpad T450 SSD Replacement: passo 3, imagem 3 %32
    • Insert a plastic opening tool into the edges of the laptop and work your way around the edges to pry off the back cover from the device.
    • Remove the back cover from the device.
  4. Lenovo Thinkpad T450 SSD Replacement, SSD: passo 4, imagem 1 %32
    • Using the JIS #00 screwdriver, remove the single 2.8 mm screw securing the SSD to the device.
  5. Lenovo Thinkpad T450 SSD Replacement: passo 5, imagem 1 %32 Lenovo Thinkpad T450 SSD Replacement: passo 5, imagem 2 %32
    • Lift the SSD up and to the left and remove it from the device.
Conclusão
Justin Ogihara
Membro desde: 09/18/17
29.253 Reputação
Autoria de 52 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 39
Últimos 30 dias: 169
Ao todo: 5,962
