Ir para o conteúdo principal
LG VX5200 Screen Replacement
jmarcum
jmarcum e 6 outros colaboradores
Última atualização em 3 de fev de 2018
10 minutos
Moderado
Introdução
Ir para o passo 1
This section covers how to disassemble the upper casing of the LG VX5200 to access the phone's screen.
O que você precisa
Ferramentas
Exibir mais…
  1. LG VX5200 Screen Replacement, Screen: passo 1, imagem 1 %32 LG VX5200 Screen Replacement, Screen: passo 1, imagem 2 %32 LG VX5200 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: passo 2, imagem 1 %32 LG VX5200 Screen Replacement: passo 2, imagem 2 %32
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: passo 3, imagem 1 %32 LG VX5200 Screen Replacement: passo 3, imagem 2 %32
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: passo 4, imagem 1 %32 LG VX5200 Screen Replacement: passo 4, imagem 2 %32 LG VX5200 Screen Replacement: passo 4, imagem 3 %32
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: passo 5, imagem 1 %32 LG VX5200 Screen Replacement: passo 5, imagem 2 %32 LG VX5200 Screen Replacement: passo 5, imagem 3 %32
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
Conclusão
Gear Up For Future Repairs
Shop all
jmarcum
Membro desde: 10/28/09
16 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 9-18, Regan Fall 2009 Membro de Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 Membros
Autoria de 2 guias
1Comentário do guia
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 30
Ao todo: 3,514
