Ir para o conteúdo principal
LG G3 Screen Assembly Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch e 15 outros colaboradores
Última atualização em 14 de ago de 2024
1 hora
Moderado
Guia em destaque
Introdução
Ir para o passo 1
Use this guide to remove or replace a broken or worn-out screen assembly including the midframe in the LG G3 (D855).
This guide shows how to replace the whole screen assembly of the LG G3 including the midframe. All components such as the vibration motor, the cameras, and the earpiece speaker need to be transferred to the replacement part during the repair process. In case you want to replace the LCD without the frame you need to follow this guide.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. LG G3 Screen Assembly Replacement, Back Cover: passo 1, imagem 1 %32 LG G3 Screen Assembly Replacement, Back Cover: passo 1, imagem 2 %32
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Screen Assembly Replacement: passo 2, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 2, imagem 2 %32
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Screen Assembly Replacement, Battery: passo 3, imagem 1 %32 LG G3 Screen Assembly Replacement, Battery: passo 3, imagem 2 %32
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Screen Assembly Replacement: passo 4, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 4, imagem 2 %32
    • Lift the battery out of its recess and remove it.
  5. LG G3 Screen Assembly Replacement, Loudspeaker: passo 5, imagem 1 %32
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Screen Assembly Replacement: passo 6, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 6, imagem 2 %32
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Screen Assembly Replacement: passo 7, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 7, imagem 2 %32 LG G3 Screen Assembly Replacement: passo 7, imagem 3 %32
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Screen Assembly Replacement, Motherboard Cover Assembly: passo 8, imagem 1 %32
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Screen Assembly Replacement: passo 9, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 9, imagem 2 %32 LG G3 Screen Assembly Replacement: passo 9, imagem 3 %32
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Screen Assembly Replacement: passo 10, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 10, imagem 2 %32 LG G3 Screen Assembly Replacement: passo 10, imagem 3 %32
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Screen Assembly Replacement, Motherboard: passo 11, imagem 1 %32 LG G3 Screen Assembly Replacement, Motherboard: passo 11, imagem 2 %32
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Screen Assembly Replacement: passo 12, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 12, imagem 2 %32
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Screen Assembly Replacement: passo 13, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 13, imagem 2 %32
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Screen Assembly Replacement: passo 14, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 14, imagem 2 %32
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Screen Assembly Replacement: passo 15, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 15, imagem 2 %32
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Screen Assembly Replacement: passo 16, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 16, imagem 2 %32
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Screen Assembly Replacement: passo 17, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 17, imagem 2 %32
    • Grab the top section of the motherboard and carefully lift it out of the phone.
  18. LG G3 Screen Assembly Replacement, Screen Assembly: passo 18, imagem 1 %32
    Can anybody comment on the size of screws used for the chassis? I am interested in thread size and length.
    Tyler Bules - Responder
    Usualy i use PH001 scrrewdriver. with strong magnet on middle of tip.
    scrapped ham -
    Hello I think the ribbon which I think is the little small part has a small rip on it can this be fixed with tape or any of their way?
    Kai - Responder
    So, based on step 10, where it says you can stop here if you have a pre-assembled frame, I bought this http://www.amazon.com/gp/product/B00T733... LCD/screen/frame. But it turns out that like all LCD/Glass/Frames it doesn't include the rear facing camera, earpiece speaker or vibrator unit. So if you buy one of those online and stop at step 10, you will not have a rear facing camera, earpiece speaker or vibrator in your "fixed" phone, those are all attached to your old frame. Now I'm going to have to separate 2 LCD/screen from 2 frames and start from the beginning, hoping I didn't damage the speaker as I tried to remove it.
    If anyone has experience with this and I'm wrong please let me know.
    Andrew Dunton - Responder
    There is no need to remove the shorter screw, it does not go through the mother board
    sunruh - Responder
  19. LG G3 Screen Assembly Replacement: passo 19, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 19, imagem 2 %32
    Ferramenta utilizada neste passo:
    • During the removal of the earpiece speaker, remove it together with the foam gasket underneath.
    • Use a pair of tweezers to remove the earpiece speaker.
  20. LG G3 Screen Assembly Replacement: passo 20, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 20, imagem 2 %32
    • Use a pair of tweezers to remove the front camera.
  21. LG G3 Screen Assembly Replacement: passo 21, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 21, imagem 2 %32
    • If you're having trouble removing the rear camera or the vibration motor, reapply the heated iOpener to loosen the adhesive underneath.
    • Use a pair of tweezers to remove the rear camera.
  22. LG G3 Screen Assembly Replacement: passo 22, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 22, imagem 2 %32 LG G3 Screen Assembly Replacement: passo 22, imagem 3 %32
    • Insert one of the tweezer arms under the vibration motor and pry it up.
    • Remove the vibration motor.
  23. LG G3 Screen Assembly Replacement: passo 23, imagem 1 %32
  24. LG G3 Screen Assembly Replacement: passo 24, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 24, imagem 2 %32 LG G3 Screen Assembly Replacement: passo 24, imagem 3 %32
    • Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
  25. LG G3 Screen Assembly Replacement: passo 25, imagem 1 %32 LG G3 Screen Assembly Replacement: passo 25, imagem 2 %32 LG G3 Screen Assembly Replacement: passo 25, imagem 3 %32
    • Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
  26. LG G3 Screen Assembly Replacement: passo 26, imagem 1 %32
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
Conclusão
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
If possible turn on your phone and test your replacement part before reassembling your phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
130 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Membro desde: 11/23/16
242.032 Reputação
Autoria de 682 guias
42Comentários do guia
Ok so after I did all this my screen is black and so I ordered a second screen and also nothing the phone works great and makes noises also touch responds but nothing on lcd just black can you help me with this also if I take battery out and plug up charger it shows a battery warning on lcd so clearly it works
cabinlife27030 - Responder
Has it sustained any water damage?
Josiah Leas -
Did you get it working i have the same issue? the picture displays with the original screen but not with the new one. i have tried 3 different screens and get the same on all of them. i even tried updating to the latest software but only get a black screen, no picture.
When i have had this on iphones i just so a reset by holding down the buttons and the screen starts to work.
Please someone help
Matt -
Same here! I also findout that lcd still works, if you get some flashlight on screen in a dark room, you will see that only backlight not working when battery plugged. I tried to baking it but it still didn't worked. It's obvious that backlight could properly operate as it works when you take off the battery. I'm looking for solutions, if I find any, will wrote it here.
tufekcisencer -
Did someone find a solution to this? I also replaced my screen and it keeps black solid when I turn it on, even with the touch working properly.
fsnaderfb -
Josiah, I have a phone like that too and it has sustained water damage…. What does that tell you? It also doesn't respond to touch…
Canse Fields -
Hello. I was just wondering if there is any advice on where to buy a good replacement screen. I was going to buy one on Amazon, but the reviews were spotty. Are there a bunch of chinese knock offs for screens? What is a reputable source?
lightman - Responder
You can look on eBay for a used screen so you know it will work. Feel free to email me if you have any questions- josiahleas@gmail.com
Josiah Leas -
I just ordered a screen on Amazon and some tools from here,installed it using this guide but have had no luck. It's just a solid black screen. Any advice or suggestions?
Matt M - Responder
so I succesfully replaced my shattered screen,but now the loudspeaker on the back of the phone no longer works. I've tried re building the phone again, and it still doesnt work. Any suggestions?
Lee Schlosser - Responder
I cracked my screen and can't unlock my phone because parts of my PIN don't register - if I replace my screen on my own, will all of the data on the phone be deleted? I checked with LG customer service and they said sending it in for official repairs deletes all the data.
aac - Responder
If you send it to them they will probably wipe all the data like they claimed but doing it yourself should have zero effect on your data.
Jerry Noftz -
They are more than likely sending you a refurbished phone back to you. That is why they claim your data will be wiped.
Justin Budd -
I have replaced the screen on an LG G3, the first one had a dead spot in the digitizing, it was replaced by the supplier without a problem and a new one was tested and working at teh store. Once installed in the frame, the only thing working is the backlight. Any input on the cause and a possible solution would be helpful
Neil Kromhout - Responder
My display doesn't work. I can't even input my password, If I fix the screen is it going to fix the display problem also?
Sarha - Responder
I successfully replaced my screen but every now and then it will register a random amount of touches on the right side of my screen
Nate - Responder
I successfully replaced my screen but now every now and then I will get a random amount of touches all up and down the right side of my screen
Nate - Responder
Has anyone resolved this problem? I did the same, and all I get is backlight?
james aakre - Responder
Kai - Responder
Hi, I actually have a question, My LCD is replaced but there seemed to be an issue, my screen is blurry. Same as when the phone was broken, only difference is that the screen isnt broken anymore. Is it possible that IO caused this by having used metal on the ribbons? Is there a way of fixing it?
Thanks in advanced.
Samaria Alvarez - Responder
This is my first time I attempt to repair a screen. I'm scared of buying a screen that might exclude the LG logo at the bottom or that the screen ends up being a cheap knockoff. Most vendors (including the one featured in the "relevant parts" list) have the image of the screen part with the logo photoshopped out. I cannot figure out if it's to avoid legal issues with LG or if their screens actually don't have the logo on it.
Am I being too paranoid or should I be searching differently?
Abraham Carrasco - Responder
I have Installed the screen but since then my battery life is decreased drastic, and i know that it's the screen because the display now takes 55% from the buttery, and before it was around 30%!
Additionally, the touch does not work good when i put a glass screen protector on it. it's a something that have never experienced before. what can we do about it? Thanks a lot...
Hava Vaiserman - Responder
the cost of buying parts for this LG3 is so high that l would opt to buy a new phone.
edwishb - Responder
I just replaced mine yesterday and when I powered it on, nothing happened. But after 10 minutes, it turned on and you can see the lock screen but you cant do anything there because the touchscreen does not work.
Arif Ali - Responder
Hello! I have broken glass on LG leon h324, but touch work good. So i need replace only glass shield. Anybody know how to separate OCA glued screen from glass? Thanks a lot!
scrapped ham - Responder
I've just cracked my screen a little but need it replaced and I was quoted £85 to replace my screen! I thought it was a bit expensive and I explained to the guy the LCD seems to be working fine but he told me it needs to be replaced as well as you can't replace the screen without replacing the LCD. Is this true?
phonixconnection - Responder
@Lee Schlosser did you find reason for loud speaker not working? I am facing similar problem after replacing the screen the loud speaker is making wierd noise
Saif Idrees - Responder
Sometimes the backlight problem (backlight remains on) is related to other issues, like unconnected or mal-functioning proximity sensor.
www.glasenframe.be
dries - Responder
May i have a briefly moment of your time? To whom it may concern, My name is Mary . I have an LG phone that it is cracked. I do not have the money or insurance to obtain a replacment screen. In fact the phone is a hand me down. It was given to me. I had no phone at the time . I had give my phone to my 10 year old son to replace his phone that hadd it stolen. Thats another story in its entirety. Let me get straight to the point now. Would any kind giving soul feel it upon their hearts be able to donate a screen repair kit and screen? Blessed we will all be if ypu are able to do so. Thank you for your time,space,and the opportunity to self educate one and all on how to problem solve our technology that has become apart of family in this transgressioning world of electronics. For my mailing address please E mail me @ mrs.mary2gooden@gmail.com anytime. Thank you again and god bless your souls. #closedmouthsdontgetfed#
Mary Wood - Responder
How much does this cost?
Kassy Leija - Responder
Successfully changed the screen, thank you!
dark - Responder
I've changed the screen finally, but I hate this phone so much. The aftermarket screens are overpriced and low quality. Never want to fix any LG phone again...
voneout - Responder
Got my g3 a while back second hand. I think it's got the motherboard replaced .(different imei in rom and oj the phone back) Also, the gray isolating tape is missing, instead there's a piece of transparent plastic there. My question is: could the lack of proper tape caude distortions in the headphone jack? (Some interference maybe?)
Bagoly Bence - Responder
There are some details of the "screen replacement with frame" missing. In addition to transferring the haptic buzzer, front and rear cameras, earpiece speaker, headphone jack, bottom board and metal shielding tape there are some small additional parts.
There are three small rubber insert parts; two on the top and one on the bottom. The last part to transfer is the ir blaster lens which is quite difficult without damaging the lens. I know since after transferring it with some difficulty I now have a severely hampered ir blaster now. Knowing this I would now opt to replace the screen only and take the time to heat the adhesive and remove replace the screen. Really the frames should be sold with the it lens installed already since it is near impossible to transfer this tiny part.
Scott Kay - Responder
my screen is getting blue
how i can fix it
hishamathar - Responder
1: Its important when repairing any device that you buy quality parts from a reputable source. Hopefully most of you know now that saving $10-15 on a inferior part does not really save you money. It in fact, takes you longer to do and more frustration. BUY GOOD PARTS, PAY EXTRA FOR GOOD PARTS. THIS WILL SOLVE MOST PEOPLE'S PROBLEM. PERIOD.
2: When replacing the screen on LG G3 it's very important that the metal mesh, On the flex cable at the bottom of the screen... is placed EXACTLY as it was placed originally in the phone before the screen repair. VERY IMPORTANT(REFER TO STEP 10). If not the screen will go in and out. If you continue to have issues with the screen afterwards.. Try putting some CapTon Tape over it. That should resolve your issues.
PS: If that does not fix it.. its the screen or the device itself. I would suggest looking for any signs of water damage or small black marks on the Mainboard (implying a short) and take pictures to show your customer so they believe you.
Jacob Bryan - Responder
i have lg g3 16gb and my brother has lg g3 32 gb my phone does not work motherboard problem and my bro lg g3 32 gb screen broken can we replace the screen of 16gb to 32 gb does it works
saireddy1201 - Responder
Hello i Change The Screen nur now The Led was Working but The Screen is Dead Any Ideas ? Thx
Mikl - Responder
Better idea about the screws: DON’T REMOVE THE SCREW CIRCLED IN RED. It holds the camera lens cover and volume/power buttons on to the plastic frame. Just take off the frame with that part still attached.
Gordon Pettey - Responder
I know this is from a long time ago but my lcd panel died after a software update. I was 28 months in and my geeksquad warranty had expired. I had visions of trying to get another year or so of use on it. I'm tired of spending 1k$ every other year. Have you guys had any success in the screen repairs?
Scott Dreyfus - Responder
I have a working LG G3 screen (44 pin connector) that I'm trying to jumper wire to a LG Zone 4/Aristo 2/Phoenix 4 (Same phone 210) with no screen (40 pin connector). I have the connector pin outs for both but I want to know is this possible to do?? Scenario: I'm on a deserted island and can't buy a replacement screen for my Zone 4. I know it's going to be a long task but are the voltages compatible?
Please contact me at s.e.davis8304@gmail.com or amebrizee@gmail.com if you know anyone who can help me with this information. Thank you.
Stephanie - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 20
Últimos 30 dias: 140
Ao todo: 249,626
