Ir para o conteúdo principal
JBL Clip 3 Speaker Replacement
Tyler Molden
Tyler Molden e 5 outros colaboradores
Última atualização em May 7, 2024
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
This guide is to help you replace the internal speaker in a JBL Clip 3.
If the original speaker in your JBL Clip 3 stops working due to a mechanical failure and causes the speaker to produce no sound at all or an unpleasant buzzing or scratching sound, use this guide to replace it with a new speaker.
Note: Before beginning, make sure to power off the JBL Clip 3, and disconnect it from any external power sources.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. JBL Clip 3 Speaker Replacement, Speaker Grill: passo 1, imagem 1 %32 JBL Clip 3 Speaker Replacement, Speaker Grill: passo 1, imagem 2 %32
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Speaker Replacement, Speaker Housing: passo 2, imagem 1 %32 JBL Clip 3 Speaker Replacement, Speaker Housing: passo 2, imagem 2 %32
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Speaker Replacement: passo 3, imagem 1 %32
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Speaker Replacement: passo 4, imagem 1 %32 JBL Clip 3 Speaker Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
  5. JBL Clip 3 Speaker Replacement, Internal Speaker: passo 5, imagem 1 %32
    • Use a Phillips #2 screwdriver to remove the two 6.3 mm screws.
  6. JBL Clip 3 Speaker Replacement: passo 6, imagem 1 %32
    • Firmly grip the speaker connection plug with tweezers and pull it straight up, perpendicular to the motherboard, to release it.
  7. JBL Clip 3 Speaker Replacement: passo 7, imagem 1 %32
    • Lift the speaker out of the housing.
Conclusão
Uma outra pessoa concluiu este guia.
Tyler Molden
Membro desde: 03/28/22
492 Reputação
Autoria de 4 guias
Equipe
3Comentários do guia
Dear Mr. Molden,
Thank you for sharing!
Do you, by any chance, have a part# for that speaker and/or know where to purchase a replacement one?
Tks in advance!
marcelo_kalil@hotmail.com
mkalil - Responder
Excelente información, dónde puedo conseguir altavoz de repuesto ?
Juan López Rodríguez - Responder
The front protective cover of my CLIP3 Bluetooth speaker fell off and is lost. Does anyone know where I can get a replacement?
Kym kymfaull@gmail.com
K Faull - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 86
Ao todo: 3,243
