JBL Clip 3 Speaker Replacement
Introdução
Ir para o passo 1This guide is to help you replace the internal speaker in a JBL Clip 3.
If the original speaker in your JBL Clip 3 stops working due to a mechanical failure and causes the speaker to produce no sound at all or an unpleasant buzzing or scratching sound, use this guide to replace it with a new speaker.
Note: Before beginning, make sure to power off the JBL Clip 3, and disconnect it from any external power sources.
O que você precisa
Peças
Ferramentas
Exibir mais…
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
Uma outra pessoa concluiu este guia.
3Comentários do guia
Excelente información, dónde puedo conseguir altavoz de repuesto ?
