Ir para o conteúdo principal
JBL Charge 3 Speaker Replacement
Aidan Hays
Aidan Hays e 4 outros colaboradores
Última atualização em June 9, 2024
3 - 6 minutos
Moderado
Introdução
Ir para o passo 1
The JBL Charge 3 has two front speaker that can be replaced individually or together. If your speakers are blown out replace them with this guide.
O que você precisa
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. JBL Charge 3 Speaker Replacement, Front Cover: passo 1, imagem 1 %32 JBL Charge 3 Speaker Replacement, Front Cover: passo 1, imagem 2 %32 JBL Charge 3 Speaker Replacement, Front Cover: passo 1, imagem 3 %32
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - Responder
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - Responder
    There are two Phillips head screws to remove before prying the cover off
    jason - Responder
    Where in south Africa can I buy jbl charge3 port bay replacement
    Donovan Fransman - Responder
    There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
    john Ramirez - Responder
    Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
    ralphkeneth_gomz - Responder
    Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
    Rowan Darko - Responder
    How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
    Bukowski101 - Responder
  2. JBL Charge 3 Speaker Replacement: passo 2, imagem 1 %32
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    Include dissembling the plastic cover? cover?
    KanGoon - Responder
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Very good guide! Pics and descriptions make this easy!
    John G Petko - Responder
    There is a step missing here. How do you remove the rubber cover that covers the port?
    Phillip Luebke - Responder
    Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
    Furkan Karakelle - Responder
    Well, broke off the cover tabs. Have to remove 2 screws first. Might add that to the instructions.🤔
    Spartacus - Responder
    Me too. Saw the screws after I'd popped it off.
    Del Taylor -
    It doesn't look fixable. Can't get the cover to stay on anymore. Ideas?
    Del Taylor - Responder
  3. JBL Charge 3 Speaker Replacement, Speaker: passo 3, imagem 1 %32 JBL Charge 3 Speaker Replacement, Speaker: passo 3, imagem 2 %32
    • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
    Die Frage : Ist ob man irgendwo Ersatz Lautsprecher bekommt ???
    nicowihnaleck - Responder
    Probier's mal hier, vergleiche aber ganz genau (Seriennummer GG…):
    https://ecommerce.mysav.eu/en/jbl/147-sp...
    VauWeh - Responder
  4. JBL Charge 3 Speaker Replacement: passo 4, imagem 1 %32
    • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
  5. JBL Charge 3 Speaker Replacement: passo 5, imagem 1 %32 JBL Charge 3 Speaker Replacement: passo 5, imagem 2 %32 JBL Charge 3 Speaker Replacement: passo 5, imagem 3 %32
    • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
    Where can l buy those speaker for replacing
    Terrence Terrence - Responder
    Somebody know where I can buy These speakers ?
    motje - Responder
    The speakers that is on my charge 3 is soldered on doesn’t have the clips in picture
    travenature - Responder
  6. JBL Charge 3 Speaker Replacement: passo 6, imagem 1 %32
    • Repeat the previous step for the second connector.
  7. JBL Charge 3 Speaker Replacement: passo 7, imagem 1 %32 JBL Charge 3 Speaker Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
  8. JBL Charge 3 Speaker Replacement: passo 8, imagem 1 %32
    • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
    where can i buy these speaker,i need to replace the left side speaker because it was already damaged
    geoffrey mustar - Responder
Conclusão
45 outras pessoas executaram este guia.
Aidan Hays
Membro desde: 10/08/18
4.050 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S13-G1, White Fall 2018 Membro de Cal Poly, Team S13-G1, White Fall 2018
CPSU-WHITE-F18S13G1
3 Membros
Autoria de 26 guias
33Comentários do guia
Where I can buy the same jbl speaker ?
Ekinox - Responder
I need to replace my JBL charge 3 speaker
Lara Esther -
Where can buy the small speakers? Helpp
Luis Cilia - Responder
I have to pull out the motherboard to get those speakers out.
Tr0ll05aur0s 3z - Responder
where can i buy the replacement speakers?
Yhamani Pangarungan - Responder
Mine did not have the little clips in step 5. It was just soldered on. I ended up removing it from the other end. At the little white clip that goes in the motherboard (shown in step &) I was able to remove the pin. by pressing down on the top where you can see the silver.
Mike - Responder
It doesn’t seem possible to buy replacement speaker units.
dave - Responder
I see them on ebay, there are two designs. Btw, my speakers don't have clips, they are soldered on.
Erwin Johnson - Responder
i just completed this repair using generic replacement speakers from ali express item number 32829635211
mine were soldered on. i had to trim 4 orientation posts that prevent the factory speakers being installed rotated incorrectly, as these wouldn’t work with the new speakers. they sound OK, but have noticeably less bass than the OEM JBL drivers and can sound a little more tinny. there are also people doing it on ebay for 30$, but i am not in the USA so that was not convenient.
ivan@absolutehid
ivan - Responder
Where can I buy these same speakers
Silvester Whitehurst - Responder
San mkabili ng orig.na speaker ng jbl3?
rodolfom.afan - Responder
where I can buy these speakers. also need it for India region . but as I checked not able to buy it .
Prince Gupta - Responder
Contact JBL customer service if y3have or gen get the teveipt call them and then email pic8or the receipt ant the JBL Serial number by the speakers when the blabk jbl grill is off if less than 12 months old youll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for Charge3 is only $32.19 USD. Good luck.
David Lorince - Responder
Contact JBL customer service if you have a charge 3. get the customer service number, call them and or then just email description fate SN# and pic of the receipt and the JBL Serial number between the speakers when the black JBL grill is off, but only if its less than 12 months old then you’ll get a free speaker replacement if out warranty or you have no receipt the replacement speaker for it is cheap only the JBL Charge3 is only $32.19 USD. Good luck.
If you can find a cheap replacement battery for $20 grab it cause its totally worth it if out in the wilderness it also acts as a cellphone charger.
Fyi upset neighbors since my left charge 3 is blown i decided it daisy chain 3 50 wayt pyle horn tweeters omg lets just day its about 500p% louder. Lol. Happy 4th of
Do you have a specific link for this OEM JBL charge 3 speaker replacement or are you just directing us to the JBL company where they currently want $35 + shipping on a single speaker unless the Charge 4 and Flip 4 lower these crazy prices. Has any one found a similar Charge 3 speaker replacement that’s louder and cheaper ???
For anyone that is wondering where to buy the speaker replacement, you can find it on all express just search up JBL charge 3 speaker replacement.
Armin Aghayan - Responder
Absolutely ridiculous how much replacement speakers are! I found some that “work” but they sound like crap…… Considering I have 4 Charge3’s and 1 Charge4, Harmon already has PLENTY of my $$!
Sheldon Abbey - Responder
JBL Charge 3 -
vorrei acquistare la coppia di casse uguale modello e dimensioni potreste fornirmi l’articolo a il link x ordinarli grazie
I would like to purchase the pair of speakers of the same model and size, could you provide me with the article at the link to order them, thank you
roberto - Responder
Ciao @flipok ! Maybe you can find some options in this Answer on our Forum: Where to buy replacement speakers for JBL Charge 3? Good luck!
Claire Miesch -
In accurate info unless they change how they put it together later down the road
Yeah, you typically do everything in reverse.
P C -
good dayhouse pls where can i buy replacement speaker for jbl charge 3 and battery any body with information thanks
EMMANUEL JUNIOR - Responder
I've ordered one. I will update after installation is done.
Rich Buffetta - Responder
Simple install. Youll need a soldering iron, some solder and a smallish phillips. Works fine now for about 10 bucks from ali.
Rich Buffetta -
Amazon, JBL.Com, Ebay.. Search for OEM JBL Charge 3 replacement speaker. Very easy.
Original speaker parts can be obtained in the UK by contacting Multicare Electronics ( +441132791255 , info@multicare.org.uk ). I initially called the Harman support line (Harman is the umbrella company of JBL), who redirected me to Multicare who are their official repair/parts company in the UK. Multicare sent me a replacement speaker unit for about £20 (ex shipping), which I have now fitted and is working perfectly. Good experience and thanks for this iFixit guide!
nixrushperseus - Responder
I got my Charge 3 used, and apparently abused. Right speaker has pin holes in the cone; left speaker missing...
My question is why would anyone ground the + input to the speakers? Both are connected to the speaker inputs and also grounded to the speaker frame...
Thanks
Perry Thompson - Responder
Quick tip on the Charge 3 is it comes in two different versions, TL model which does have those clips on the transducers while the GG model has directly soldered connectors. Here is a comparison.\/
TL: Spade style speaker connection.
Difference:Mic design, passive mount type, enclosure, etc., One is made in China while the other in Vietnam.
GG: Directly soldered speaker connection.
Hopefully this helped someone out there ;) ps. The unit shown is a TL model, I would know because I own a black charge 3 TL.
POTATOhasAjbl - Responder
Comentar
Visualizações:
Últimas 24 horas: 26
Últimos 7 dias: 140
Últimos 30 dias: 618
Ao todo: 97,571
