How to replace Huawei P9 LCD Display?
Introdução
For the official iFixit repair guide, click here. The guide you are viewing is retained for historical purposes only.
This video demonstrates how to replace your Huawei P9 LCD screen with a few basic tools.
O que você precisa
Peças
Ferramentas
Exibir mais…
Instruções em vídeo
8 outras pessoas executaram este guia.
9Comentários do guia
I have a Huawei P9 and the LCD screen is broken.
I'm thinking that I want to try to repair it on my own - but before I do that I would like to ask a few things.
I was watching the Huawei P9 teardown video and it seems to me that before I can replace the screen then I need to remove the battery from it's place.
The question is do I use any battery sticker or must I use a battery sticker designed for the Huawei P9.
Zecht - Responder
Actually, you need to remove the battery indeed.Because the LCD Screen Flex is underneath. And note that the battery removal is a little tough.You can watch the video of http://bit.ly/how-to-remove-battery-for-... first.In addition,if you don't know how to remove other small components for Huawei P9,here is the http://bit.ly/Complete-Repair-Guide-for-.... Wish you luck!
Witrigs -
I just need its screen but it's not available on market ... I don't have a warranty card , i lost it... Help plz
anasjed - Responder
It is available now at http://www.witrigs.com/oem-lcd-with-digi...
Witrigs -
My Huawei P9 screen is broken but it is still working must I replace the whole LCD screen or just the front cover.
magdayork - Responder
You need to replace full front screen. it is really difficult to replace front glass only.
Witrigs -
This is not even close to how you do it. This is just a small part of it, this video leaves out the part where EVERYTHING comes out with the screen, its just the backcover which is removed when you open it up. you need to remove, the battery, sim-tray, motherboard, daughterboard and the speaker to be able to remove the screen. This video is misguiding. It is VERY hard to replace this screen, do not try it if you are not very experienced with mobile repair.
Johan Andersson - Responder
my screen broke and I changed it by a new one that worked for an hour, but after that the screen turned off but operating system is still turned on, I have tried 2 screens and nothing, what is the problem??
peikin - Responder
Hi. My Hauwei p9 screen just broke. How can I get the screen fixed and from where can I get it. Thanks. Zinny
Kalu Ezinne - Responder
