Ir para o conteúdo principal
How to Powerwash reset a Chromebook
Jacob Mehnert
Jacob Mehnert e um outro colaborador
Última atualização em June 19, 2024
5 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
While Google's ChromeOS devices are a nice low cost alternative to Windows and Mac computers, they do occasionally have stubborn issues that can't seem to be fixed.
Should an issue like this occur, restoring your device to the factory state may be necessary. You would also want to do this if you plan on passing along your device to a new owner, and you would want your personal information removed from the device beforehand.
Regardless of the reason, ChromeOS' Powerwash feature can be used to return the device back to the factory state.
    • All Local files and settings will be erased once the device is Powerwashed.
    • While most of Chrome OS' files are specific to the user's account there are still some files that are stored locally, and will be permanently deleted once Powerwashed.
    • Any files that are saved to your devices local drive are often stored in the Downloads folder. This folder should always be backed up to either an external device, or your Google Drive before the Powerwash process.
    • Any Google Accounts that were previously used on the device will be removed once the device is Powerwashed, along with settings that are associated with the account. These accounts can be rested to the device, given that you have the account information beforehand.
    • If you intend on turning your device over to a new owner, do not ender your account information once the process it complete.
    • Powerwashing the device does not remove any enterprise enforced profiles, and does not remove any MDM profiles.
    • Open the Chrome Browser and click the menu button (three vertically-aligned dots).
    • Select Settings and choose Advanced.
    • Scroll down until you locate the Reset settings section, and choose the Powerwash option.
    • A dialog box titled Restart your device will be displayed. Click on Restart. The device will restart and the Powerwash process will be complete.
    • From the login screen, press the following the keyboard shortcut: Shift + Ctrl + Alt + R
    • A window will appear titled Reset this Chrome device. Choose the Restart option to begin the process. The device will restart.
    • Once the device is reset, a new window will display. Click the Powerwash button, and confirm the Powerwash by clicking Continue.
Conclusão
Once the process is complete, simply follow the on screen instructions to log back in. If you intend on giving your device to a new owner, then you are finished.
8 outras pessoas executaram este guia.
Jacob Mehnert
Membro desde: 10/18/21
39.610 Reputação
Autoria de 50 guias
Equipe
iFanatics Membro de iFanatics
Community
61 Membros
Autoria de 194 guias
2Comentários do guia
How to remove it from a chromebook from school enterprise??
Kevin Luengas - Responder
You would need to contact your school's IT department and have it deprovisioned by them.
Jacob Mehnert -
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 66
Ao todo: 2,635
