Ir para o conteúdo principal
How to Perform a Battery Cycle Reset
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl e 3 outros colaboradores
Última atualização em 29 de jun de 2025
2 - 5 minutos
Fácil
Introdução
Ir para o passo 1
Use this guide to perform a battery cycle reset on your Samsung phone or tablet. You should perform this reset whenever you change the battery for your Samsung device.
Tested Devices (Samsung Remote Test Lab):
  • Supported S Phones: S20, S20+, S20 Ultra, S21, S21+, S21 Ultra, S21 FE, S22, S22+, S22 Ultra, S23, S23+, S23 Ultra, S23 FE, S24, S24+, S24 Ultra
  • Supported A Phones: A15, A25, A54
  • Supported Fold Phones: Z Fold5
  • Supported Flip Phones: Z Flip5
  • Supported S Tablets: Tab S7+, Tab S9, Tab S9+, Tab S9 Ultra, Tab S9 FE, Tab S9 FE+
  • Unsupported S Phones: S20 FE, S24 FE, S25, S25+, S25 Ultra
  • Unsupported A Phones: A04, A05, A06, A13, A13 5G, A14, A16, A22, A23, A24, A31, A32, A32 5G, A33, A34, A35, A42 5G, A52s, A53, A55 5G, A72, A73, A82 5G
  • Unsupported Note Phones: Note20, Note20 Ultra
  • Unsupported Fold Phones: Z Fold1, Fold2, Fold3, Fold4, Fold6
  • Unsupported Flip Phones: Z Flip1, Flip2, Flip3, Flip4, Flip6
  • Unsupported Tablets: Tab S7, Tab S7 FE, Tab S8, Tab S8+, Tab S8 Ultra, Tab S10+, Tab S10 Ultra
For more information, refer to the Samsung Self-Repair document.
Note: the device used is a Samsung Galaxy Tab S7+, but the procedure is identical across all Samsung devices.
Note: Samsung account required.
  1. How to Perform a Battery Cycle Reset, Download the app: passo 1, imagem 1 %32 How to Perform a Battery Cycle Reset, Download the app: passo 1, imagem 2 %32 How to Perform a Battery Cycle Reset, Download the app: passo 1, imagem 3 %32
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
    The Self Repair Assistant is now working on one ui 6.1
    Jayson Chua - Responder
    Je trouve mas l'application
    Oussama Reddaf - Responder
    Make sure to set your phone date to year 2022 before using this app version. If you don't, it will not work and ask you to download the latest version.
    Do not use the latest version of this app as it will ask for Samsung-made battery serial number (really Samsung. copying Apple for this is anti-consumer).
    Peter Chang - Responder
    Je ne retrouve pas l'application
    Boukar - Responder
  2. How to Perform a Battery Cycle Reset, Install the app: passo 2, imagem 1 %32 How to Perform a Battery Cycle Reset, Install the app: passo 2, imagem 2 %32
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
    It says model not supported
    kayceegovender24 - Responder
  3. How to Perform a Battery Cycle Reset, Rename the app: passo 3, imagem 1 %32 How to Perform a Battery Cycle Reset, Rename the app: passo 3, imagem 2 %32 How to Perform a Battery Cycle Reset, Rename the app: passo 3, imagem 3 %32
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Perform a Battery Cycle Reset: passo 4, imagem 1 %32 How to Perform a Battery Cycle Reset: passo 4, imagem 2 %32 How to Perform a Battery Cycle Reset: passo 4, imagem 3 %32
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
    Su s20 con one ui 5.1 viene fuori il messaggio di aggiornare l app
    _matti_ - Responder
  5. How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: passo 5, imagem 1 %32 How to Perform a Battery Cycle Reset, Open the Galaxy Cal app: passo 5, imagem 2 %32
    • Select the Galaxy Cal app.
    Bei meinem S20 FE 5G kommt beim Starten der App die Meldung:
    This Model is NOT Supported
    Gibt es sonst noch eine Möglichkeit?
    DasMarki _ - Responder
    Says galaxy s20fe is not supported?
    Leroy Henkeman - Responder
    I want FE support as I have an S20 FE 5G.
    Evan Mcgeehan - Responder
    It doesn't work on galaxy s20 with one ui 5.1
    _matti_ - Responder
    On my S9 it installs but the window of the app closes instantly after opening.
    Rbn Vn Drn - Responder
  6. How to Perform a Battery Cycle Reset, Agree to the terms and conditions: passo 6, imagem 1 %32
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Perform a Battery Cycle Reset, Select the procedure: passo 7, imagem 1 %32 How to Perform a Battery Cycle Reset, Select the procedure: passo 7, imagem 2 %32
    • Select the "Battery" icon.
    • Select "Calibrate" to continue.
    • If you want to perform a fingerprint sensor calibration instead, follow this guide.
  8. How to Perform a Battery Cycle Reset: passo 8, imagem 1 %32 How to Perform a Battery Cycle Reset: passo 8, imagem 2 %32 How to Perform a Battery Cycle Reset: passo 8, imagem 3 %32
    • Select the "Start" button.
    • Select the "Start" button again.
    • Select "Ok" to finalize the battery cycle reset.
    • Wait until the battery cycle reset finishes.
    • You may need to reset your device for battery cycle reset to apply.
    _matti_ - Responder
Linha de Chegada
14 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Alex Diaz-Kokaisl
Membro desde: 01/16/22
179.624 Reputação
Autoria de 829 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 22.373 guias
42Comentários do guia
Thanks for catching that! I fixed the link in the introduction.
Arthur Shi -
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
Pierre-Luc Thibeault - Responder
I have the same. Do you know how to fix this now?
Melanie Herget -
simply change your phone date between 2021 and 2022.
mightnire -
When opening the app it says model not supported .I'm using a galaxy-s20-fe
Sankt Florian - Responder
me too. cant find in store either
Chad Paul -
Set your phone date between 2021 to 2022
蓝泽希 -
Please update the newest version
kramyeu - Responder
Hello again, when the prompt show there yoy should get new version just simple change the date back in past
kramyeu - Responder
Good catch! I changed it to Sept 30 2022 and then the app started.
Oscar de León -
I installed the galaxy cal app on an S20, Android 13 too and when opening the app I get a message to try again after getting new version.
Tried on 3 devices, same result :(
Holger Dahlke - Responder
Resetting the date was the right clue, thx :)
Holger Dahlke -
I have the same question that the application shows it needs updating before opening it. Version is SM-G9860, Oneui5.1
James Zhao - Responder
note20 ultra show : This model is NOT supported! could you add note20 to this tool?
Fixxx - Responder
I hope to see an increase in compatibility for the Note20 series.
Kaiming Zhang (土豆丝) - Responder
Can you please add support for the fe series devices because I have an s20 fe 5g and need to replace my battery.
Would be nice to have, but not possible. As the Prolog says:
Diese Vorgehensweise funktioniert nur auf dem S20, S21, S22 und TabS7+ Modellen. Sie gilt nicht für Fan Edition (FE) Modelle. Diese Anleitung wird aktualisiert, sobald Samsung weitere Modelle hinzufügt.
"... Not suitable for the Fan Edition (FE) Modells. ..."
BenZ78 -
Can you please add s23 series support for in the future as I have an S23 Ultra. Also for those of you who have the "try again after getting new version" error just change your device's date to Oct. 1st 2022 or earlier.
No need to change the phones date just update the app after installing using the galaxy store.
Chris - Responder
Does it work with a S20+ too?
Daniel - Responder
Hallo,
danke für Euren Tipp.
Ich habe diese Version für mein S22 plus heruntergeladen und installiert. Nach dem Start der App, wollte die App aktualisiert werden. Habe ich gemacht und jetzt will die App eine Seriennummer meines Akkus. Version 2.0.10
Kann ich das irgend wie auslesen lassen?
Mfg
dachs1 - Responder
Is there a compatible version for the Samsung S10E?
Elia Capecci - Responder
Did you try the latest version 2.0.12 from the Samsungparts link in step 1 in the unverified but updated version of this guide?
Evan Mcgeehan -
Hi all. Why doesn't the program support Samsung 20FE? Is there a way to reset the charge counter?
Андрей Александров - Responder
Hallo
Leider sagt die app das ei e Verwendung auf dem s21fe nicht möglich ist. Gibt es dafür Lösungsansätze?
benbaschke - Responder
Use the latest version 2.0.12 in the unverified version of this guide. I tested it on devices in Samsung's Remote Test Lab and it should work for your S21FE.
Verwenden Sie die neueste Version 2.0.12 in der nicht verifizierten Version dieses Handbuchs. Ich habe es auf Geräten im Remote Test Lab von Samsung getestet und es sollte für Ihr S21FE funktionieren.
Evan Mcgeehan -
Change phone date to 2021
jackyang0320 -
when i start the calibration, the apps shows that need a serial or qr of the battery, how can i get it?
juandavidflexia - Responder
at the back of the battery there is QR code or at the front I am not so sure which one to use. there is also serial number beside the QR code at the back
Ray Floyd Cabrera -
Hallo, can i use it for my galaxy S21 5G ?
Johann Gottlieb - Responder
Yes I've tested it on that model in Samsung's Remote Test Lab on their developer website and it works.
Evan Mcgeehan -
Is it for Samsung only?
Aj Mea - Responder
Yes, this tutorial is especially for the Samsung models mentioned in the introduction.
BenZ78 -
it can support a52s ?
Strong demand, expected renewal
I changed the battery and saw that the battery level was 0%, but the battery still had an output of 3.6V.
The output voltage range of lithium batteries is 2.8V~4.2V, and the voltage corresponding to 0% power should be 2.8~3.2V
The battery cycle counter limits the capabilities of my new battery
蔚沐白 - Responder
Unfortunately even the latest version as of writing (2.0.12) doesn't work on the A52s. I installed and launched it on an A52s in Samsung's Remote Test Lab as this is how I tested all the listed devices in this guide and it said the model isn't supported. Indeed that is also correct as to why resetting the cycle count is important when replacing the battery. The phone limits how much of even a brand new battery's capacity is used based on the stored cycle count and calculated health percentage in the devices memory unless it's reset with this tool.
Evan Mcgeehan -
Hi sir
How can i do it for the note 20 ultra please i need a solution
thug Namroud - Responder
Currently even the latest version (2.0.12) doesn't support the Note 20 or Note 20 Ultra.
Evan Mcgeehan -
is it support note10+?
張奕斯 - Responder
I'm not sure as it's not listed on Samsung's Remote Test Lab for me to test. You can try the latest version (2.0.12) on your Note10+ to see if it's supported.
Evan Mcgeehan -
My new battery was installed at a repair shop but they did not have software to recalibrate nor did they provide me with serial number. I was told to just allow battery to drain to 0%, then recharge to 85% a few times and it will recalibrate after a few cycled. NOT TRUE. How can I recalibrate new battery in my S20+ 5G without Serial Number of new battery? Also the name of APK file in link above differs from documenation ... file starts with GPT. but documenation shows file name should have been SRA... IS THIS GPT FILE SAFE? I have very low tech skills -- just a retired grandma who wants the battery to hold a charge so I can keep my phone. Thx for any help!
Jane Hylton - Responder
Comentar
Visualizações:
Últimas 24 horas: 130
Últimos 7 dias: 714
Últimos 30 dias: 3,358
Ao todo: 92,347
