Ir para o conteúdo principal
How to Install an M.2 SSD
Chayton Ritter
Chayton Ritter e 3 outros colaboradores
Última atualização em April 6, 2025
2 - 5 minutos
Fácil
Guia em destaque
Introdução
Ir para o passo 1
Follow this general guide to learn how to install an M.2 SSD in your laptop.
Before you work on your laptop, be sure to completely power off and unplug it. Make sure the laptop is not in standby, sleep, or hibernation mode.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. How to Install an M.2 SSD, Reposition the standoff: passo 1, imagem 1 %32 How to Install an M.2 SSD, Reposition the standoff: passo 1, imagem 2 %32
    • If your laptop did not include a removable standoff or only supports one M.2 SSD form factor, you can skip this step.
    • Use a screwdriver to remove the preinstalled standoff.
    • If your laptop does not include a preinstalled standoff, you will need to get one.
    • Find the correct standoff location that corresponds to your desired M.2 SSD form factor.
    • Screw in the standoff.
  2. How to Install an M.2 SSD, Insert the SSD: passo 2, imagem 1 %32 How to Install an M.2 SSD, Insert the SSD: passo 2, imagem 2 %32 How to Install an M.2 SSD, Insert the SSD: passo 2, imagem 3 %32
    • Grip the SSD on the sides near the screw indent.
    • Gently slide the SSD into the socket at about a 30˚ angle.
    • The socket is spring loaded and will support the SSD at an angle.
  3. How to Install an M.2 SSD, Screw down the SSD: passo 3, imagem 1 %32 How to Install an M.2 SSD, Screw down the SSD: passo 3, imagem 2 %32 How to Install an M.2 SSD, Screw down the SSD: passo 3, imagem 3 %32
    • Use your finger to hold the SSD down horizontally, making sure that the screw indent aligns with the standoff.
    • Screw down the SSD to secure it.
  4. How to Install an M.2 SSD, Apply a thermal pad: passo 4, imagem 1 %32 How to Install an M.2 SSD, Apply a thermal pad: passo 4, imagem 2 %32 How to Install an M.2 SSD, Apply a thermal pad: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • If your laptop did not have a thermal pad installed, you can skip this step.
    • Use tweezers or your fingers to place a thermal pad on the top of the SSD.
    • The original thermal pad can be reused if it is clean and undamaged.
Conclusão
Installation didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
10 outras pessoas executaram este guia.
Chayton Ritter
Membro desde: 08/21/20
22.655 Reputação
Autoria de 105 guias
Equipe
Guide Team Membro de Guide Team
Staff
9 Membros
Autoria de 11.555 guias
1Comentário do guia
muchas gracias por la ayuda amigo dios t bendiga
Jose Percy Castro Carrera - Responder
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 93
Últimos 30 dias: 561
Ao todo: 7,222
