How to Fix a Sticking Deadbolt
Introdução
Ir para o passo 1A sticking deadbolt is a common nuisance for homeowners. It can be caused by debris, weather, and general wear and tear. This guide will instruct users how to repair a sticking deadbolt. Fortunately, this is an intermediate fix and the estimated time to complete this repair is thirty to forty-five minutes.
O que você precisa
Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
After following this fast fix guide, the sticking deadbolt should be fixed.
6 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all2Comentários do guia
Thank you! GumOut worked well. (I was amused to realize I already had it in my shed for cleaning my lawn mowers carburetor.) In my situation the deadbolt wouldn't fully retract with the key any more, but I could push it the rest of the way with my finger. After removing the latch in step 3, I could turn the latch with a flat head screwdriver and find the place where it "sticks." After cleaning the latch out with a few sprays of GumOut and exercising it with a flat head screwdriver, the latch was working smoothly again. Thank you for the helpful guide!
