Ir para o conteúdo principal
How to Clean Stains On A Baking Sheet
Ashlee Takushi
Ashlee Takushi e 3 outros colaboradores
Última atualização em 22 de mai de 2024
25 minutos
Muito fácil
Introdução
Ir para o passo 1
Staining a baking sheet makes the item look worn and filthy. Use this guide to clean your kitchenware quickly and easily.
O que você precisa
Ferramentas
Exibir mais…
  1. How to Clean Stains On A Baking Sheet, How to Clean Stains On A Baking Sheet: passo 1, imagem 1 %32
    • Place the dirty baking sheet on a flat surface.
    • Tip: This method can be used on stained pots and pans as well.
    • Tip: This method works best if you clean the stained baking sheet as soon as it has cooled after use.
    • Note: The liquid on the baking sheet is grease. This method will work whether or not there is grease on the baking sheet
  2. How to Clean Stains On A Baking Sheet: passo 2, imagem 1 %32 How to Clean Stains On A Baking Sheet: passo 2, imagem 2 %32
    • Cover the stained part of the baking sheet with a thin layer of baking soda.
  3. How to Clean Stains On A Baking Sheet: passo 3, imagem 1 %32 How to Clean Stains On A Baking Sheet: passo 3, imagem 2 %32
    • Pour a small amount of water over the baking soda so the baking soda looks pasty.
    • Tip: Do not put too much water on the baking soda, as it will cause the baking soda to spread and not stay on the desired cleaning area.
  4. How to Clean Stains On A Baking Sheet: passo 4, imagem 1 %32
    • Set a timer for 15 minutes, press start, and wait until timer goes off.
  5. How to Clean Stains On A Baking Sheet: passo 5, imagem 1 %32 How to Clean Stains On A Baking Sheet: passo 5, imagem 2 %32
    • Take a sponge and clean the desired area.
    • Tip: If the baking soda becomes too thick when scrubbing, add more water.
    • Tip: Using the rough side of the sponge makes cleaning easier.
  6. How to Clean Stains On A Baking Sheet: passo 6, imagem 1 %32 How to Clean Stains On A Baking Sheet: passo 6, imagem 2 %32 How to Clean Stains On A Baking Sheet: passo 6, imagem 3 %32
    • Rinse off the baking soda and wash the baking sheet again with soap and water.
    That looks like a teflon coated baking sheet? I would not recommend using a green (coarse ) scotchbrite pad on a teflon coated surface as you will damage the coating!
    I. Margaronis - Responder
Conclusão
Congratulations! You have a baking sheet that looks good as new.
31 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Ashlee Takushi
Membro desde: 02/24/15
1.129 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-5, Green Winter 2015 Membro de Cal Poly, Team 23-5, Green Winter 2015
CPSU-GREEN-W15S23G5
4 Membros
Autoria de 9 guias
3Comentários do guia
I’ve also had good success getting stains off stainless steel following a similar process but using cream of tartar + vinegar instead of baking soda + water. Cream of tartar with vinegar forms an acidic paste instead of the alkaline paste of the baking soda. Of course, don’t mix these approaches or expect unhelpful frothiness.
Don - Responder
Don, thanks for the additional tips, especially the acidic versus alkaline aspects.
Mike Rehbein -
is that a non stick baking sheet? How is it on steel?
Christine Shriam - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 83
Ao todo: 9,268
