Ir para o conteúdo principal
How To Remove Rust From Old Tools
Geoff Wacker
Geoff Wacker e 2 outros colaboradores
Última atualização em 31 de jul de 2024
15 minutos
Fácil
Introdução
Ir para o passo 1
Do you have some rusty old tools laying around the house? Use this guide to remove that pesky rust and return your tools to good working condition.
O que você precisa
Ferramentas
Exibir mais…
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, imagem 1 %32 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, imagem 2 %32
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: passo 2, imagem 1 %32 How To Remove Rust From Old Tools: passo 2, imagem 2 %32
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: passo 3, imagem 1 %32 How To Remove Rust From Old Tools: passo 3, imagem 2 %32 How To Remove Rust From Old Tools: passo 3, imagem 3 %32
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: passo 4, imagem 1 %32 How To Remove Rust From Old Tools: passo 4, imagem 2 %32 How To Remove Rust From Old Tools: passo 4, imagem 3 %32
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: passo 5, imagem 1 %32
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
    you need to use a zoom in picture in step 4 for step 5!
    stephen harrison - Responder
Conclusão
11 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Geoff Wacker
Membro desde: 09/30/13
91.525 Reputação
Autoria de 89 guias
2Comentários do guia
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Responder
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 32
Últimos 30 dias: 149
Ao todo: 6,643
