HUAWEI HONOR 5X Battery Replacement
Introdução
Ir para o passo 1The battery should be inspected if the phone is constantly overheating and powering off.
O que você precisa
Remove the pink sticker.
7 outras pessoas executaram este guia.
4 comentários
Just did this successfully, thanks for the steps.
I’d suggest adding to BE CAREFUL WHEN PRYING OUT THE BATTERY. #1 there is the screen cable under there and if you damage that, then have fun getting a new screen. #2 lithium batteries can ignite when punctured (like I did). Go easy working your way in and take note of where the screen cable is (lower black cable in step 9 image).
Anyone know where I can get replacement 1.17mm Torx T3 screws? Mine came stripped. I had a tough time getting them out and don’t want to use the same ones to put back in.
