Ir para o conteúdo principal
HP Slate 7 4601 Motherboard Replacement
Davis Muxlow
Davis Muxlow e 4 outros colaboradores
Última atualização em October 3, 2018
20 - 30 minutos
Moderado
Introdução
Ir para o passo 1
This device's motherboard is a green, "L"-shaped component internally located against the front screen and beneath the battery. Replacement requires the removal of the battery prior to removing the motherboard and involves the disconnection of two gold ribbons and 6 screws. In this guide, you will be removing the following:
  1. Back Cover
  2. Battery
  3. Charging Port
  4. Speaker Unit
  5. Motherboard
If the guide steps are accurately followed, replacement should be a breeze. So, prepare your required tools, a new motherboard for your tablet, and set aside about 20 to 30 minutes to delve into the inner workings of your HP Slate.
O que você precisa
Ferramentas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • T4 Torx Screwdriver
    T4 Torx Screwdriver
Exibir mais…
  1. HP Slate 7 4601 Motherboard Replacement, Battery: passo 1, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Begin your replacement by using a T3 or T4 Torx screwdriver.
    • Remove the two 1.4mm x 3mm Torx Head screws at the top of the device.
    On the HP 10 Plus 2201 there are no head screws. I used the spudger to 'carefully' separate the case. There are little snaps on the inside of case that will separate with little pressure on spudger.
    RB Richter - Responder
    I used these directions to replace HP Plus 10 2201 battery. I bypassed speaker installation.
  2. HP Slate 7 4601 Motherboard Replacement: passo 2, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 2, imagem 2 %32
    • With the pointed end of the spudger, remove the thin metal band.
    • It is easiest to remove the metal band through the headphone opening.
    On HP 10 Plus 2201 there is no metal band. The case simply unsnaps apart.
  3. HP Slate 7 4601 Motherboard Replacement: passo 3, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 3, imagem 2 %32
    • Using the flat end of the spudger, pry back the rear plastic cover.
    • As you work your way around the edge, several "pop" noises will be made. These noises are caused by the plastic clips coming undone.
    This is basically how I opened my HP 10 Plus 2201. "Using the flat end of the spudger, pry back (apart) the rear plastic cover from tablet.
  4. HP Slate 7 4601 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the rear cover.
  5. HP Slate 7 4601 Motherboard Replacement: passo 5, imagem 1 %32
    • Locate and remove the yellow tape covering the red and white speaker wires.
    The inside of my HP 10 Plus 2210 looks similar but not exactly as this illustration
    The battery connections weren't the plug in type. The three battery battery wires (red, white, & black) were soldered into place,
  6. HP Slate 7 4601 Motherboard Replacement: passo 6, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 6, imagem 2 %32
    • Using the pointed end of the spudger, push both sides of the speaker wire connector out of its base.
    • Push the same amount on both sides of the connector to avoid jamming or twisting its metal pins.
    • Do not yank or pull on the speaker wires, since they are fragile. Only push on the white connector.
    Do not pull on wires. Never force anything.
    note the route of the speaker cables round the battery
    Alan Boddey - Responder
  7. HP Slate 7 4601 Motherboard Replacement: passo 7, imagem 1 %32
    • Gently pull back the foil covering the gold charging port ribbon.
    Hpcom Support Helps HP Printer users to download and install All Hp Printers drivers. We also provide all possible solutions to fix hp Printer problems. If you face any issue in install Hp printer driver or having other problems with the hp Printer, you can follow our 100 % working solutions. In case you can’t able to continue printing, then feel free to contact us. We are happy to serve you.
    hpcom us - Responder
  8. HP Slate 7 4601 Motherboard Replacement: passo 8, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 8, imagem 2 %32
    • Using the flat end of the spudger, lift up the black panel covering the charging port connector.
    • Gently slide the charging port ribbon out from its housing.
    • It may be easier to use the pointed end of the spudger than your fingers.
  9. HP Slate 7 4601 Motherboard Replacement: passo 9, imagem 1 %32
    • Lift gold charging strip away from the battery.
  10. HP Slate 7 4601 Motherboard Replacement: passo 10, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 10, imagem 2 %32
    • Push the white battery connector out of its housing using the pointed end of the spudger.
  11. HP Slate 7 4601 Motherboard Replacement: passo 11, imagem 1 %32
    • Using the #00 Phillips Head screwdriver, remove the 5 screws holding the battery in place.
    • The four 1.75mm x 3mm silver Phillips Head screws circled in red are interchangeable.
    • The black 1.75mm x 4mm Phillips Head screw must go back to the same spot during reassembly.
  12. HP Slate 7 4601 Motherboard Replacement: passo 12, imagem 1 %32
    • Lift battery out of its place and set aside.
  13. HP Slate 7 4601 Motherboard Replacement, Motherboard: passo 13, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement, Motherboard: passo 13, imagem 2 %32
    • Disconnect the LCD screen ribbon by lifting up the black panel with the flat end of a spudger and sliding the gold strip out.
    • When reconnecting the LCD connector ribbon, make sure that it's pushed in all the way. If it isn't, there will be horizontal lines when you power the tablet on.
  14. HP Slate 7 4601 Motherboard Replacement: passo 14, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 14, imagem 2 %32
    • Likewise, disconnect the square radio chip ribbon by lifting up the black panel with a spudger and sliding the gold strip out.
  15. HP Slate 7 4601 Motherboard Replacement: passo 15, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 15, imagem 2 %32
    • You will be using a #00 Phillips Head screwdriver to free the motherboard.
    • Remove the six 1.75mm x 3mm Phillips Head screws holding the motherboard to the screen.
  16. HP Slate 7 4601 Motherboard Replacement: passo 16, imagem 1 %32 HP Slate 7 4601 Motherboard Replacement: passo 16, imagem 2 %32
    • Using your hand, lift up the silver tape from the copper plate.
    • Lift the motherboard out of the device.
    • You may need to wiggle and work the motherboard to get it released from the device
    You will need to transfer the camera from the old motherboard to the new.
    Gently disconnect the connector marked “BYD”.
    Gently press down on the camera lens in order to release ir from the board and feed the connector through the motherboard by turning the connector in a diagonal position in order to feed it through the motherboard.
    rmeischner@comcast.net - Responder
Conclusão
4 outras pessoas executaram este guia.
Davis Muxlow
Membro desde: 04/14/14
242 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 13-30, Maness Spring 2014 Membro de Cal Poly, Team 13-30, Maness Spring 2014
CPSU-MANESS-S14S13G30
3 Membros
Autoria de 8 guias
Um comentário
We have 7 inch Hp tablet please replace motherboard sir
Sushmitha - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 3,828
