Ir para o conteúdo principal
HP Pavilion 15-cd040wm CD Drive Replacement
Brian Cornet
Brian Cornet e 2 outros colaboradores
Última atualização em December 30, 2019
15 - 30 minutos
Fácil
Introdução
Ir para o passo 1
If your CD drive fails to read any disk or fails to open when pressing the eject button, you most likely have a faulty CD drive that requires replacement.
To access the CD drive, you will first need to open your HP Pavilion 15-cd040wm by disassembling its back cover.
Before beginning, make sure to power off your laptop completely and disconnect it from any external power source. Once the back cover is off, be sure to disconnect the battery from the motherboard to ensure there is no power going to the laptop while it is being worked on.
O que você precisa
Ferramentas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, imagem 1 %32 HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: passo 1, imagem 2 %32
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm CD Drive Replacement: passo 2, imagem 1 %32 HP Pavilion 15-cd040wm CD Drive Replacement: passo 2, imagem 2 %32
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm CD Drive Replacement: passo 3, imagem 1 %32 HP Pavilion 15-cd040wm CD Drive Replacement: passo 3, imagem 2 %32 HP Pavilion 15-cd040wm CD Drive Replacement: passo 3, imagem 3 %32
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm CD Drive Replacement, Battery: passo 4, imagem 1 %32 HP Pavilion 15-cd040wm CD Drive Replacement, Battery: passo 4, imagem 2 %32
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm CD Drive Replacement: passo 5, imagem 1 %32 HP Pavilion 15-cd040wm CD Drive Replacement: passo 5, imagem 2 %32
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: passo 6, imagem 1 %32 HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: passo 6, imagem 2 %32
    • Slide the CD drive out the side of the laptop.
Conclusão
Brian Cornet
Membro desde: 10/21/19
316 Reputação
Autoria de 3 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 32
Ao todo: 570
