Ir para o conteúdo principal
HP Mini 311 WWAN Card Replacement
Christian Santoyo
Christian Santoyo e 4 outros colaboradores
Última atualização em July 17, 2018
6 minutos
Fácil
Introdução
Ir para o passo 1
If you are having problems with internet connection, you may want to replace your wireless network card on your HP Mini 311.
O que você precisa
Ferramentas
  1. HP Mini 311 WWAN Card Replacement, Battery: passo 1, imagem 1 %32 HP Mini 311 WWAN Card Replacement, Battery: passo 1, imagem 2 %32 HP Mini 311 WWAN Card Replacement, Battery: passo 1, imagem 3 %32
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 WWAN Card Replacement: passo 2, imagem 1 %32 HP Mini 311 WWAN Card Replacement: passo 2, imagem 2 %32
    • Slide the battery away from the device to remove.
  3. HP Mini 311 WWAN Card Replacement, Memory Shield: passo 3, imagem 1 %32
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 WWAN Card Replacement: passo 4, imagem 1 %32 HP Mini 311 WWAN Card Replacement: passo 4, imagem 2 %32
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 WWAN Card Replacement, WWAN Card: passo 5, imagem 1 %32 HP Mini 311 WWAN Card Replacement, WWAN Card: passo 5, imagem 2 %32 HP Mini 311 WWAN Card Replacement, WWAN Card: passo 5, imagem 3 %32
    • Begin by removing the red and blue wires from the wireless card.
    • Gently remove to avoid damaging the ends of the wires.
  6. HP Mini 311 WWAN Card Replacement: passo 6, imagem 1 %32
    • Remove the two Phillips 00 3.8mm screws attached to the wireless card.
  7. HP Mini 311 WWAN Card Replacement: passo 7, imagem 1 %32 HP Mini 311 WWAN Card Replacement: passo 7, imagem 2 %32 HP Mini 311 WWAN Card Replacement: passo 7, imagem 3 %32
    • Lift up the unattached side of the wireless card and pull out to remove.
Conclusão
Christian Santoyo
Membro desde: 01/31/13
495 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-4, Maness Winter 2013 Membro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Membros
Autoria de 10 guias
1Comentário do guia
I don't have red and blue wires visible, are they tucked behind something? My pcie slot is vacant. What compatible part can i put here to increase speed and/or wireless connectivity?
Samant - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 1,492
