Ir para o conteúdo principal
HP Mini 311 RAM Replacement
Christian Santoyo
Christian Santoyo e 5 outros colaboradores
Última atualização em January 28, 2014
4 minutos
Fácil
Guia em destaque
Introdução
Ir para o passo 1
If you want to increase your computers memory or are having trouble with speed, the RAM is simple to replace in HP Mini 311.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. HP Mini 311 RAM Replacement, Battery: passo 1, imagem 1 %32 HP Mini 311 RAM Replacement, Battery: passo 1, imagem 2 %32 HP Mini 311 RAM Replacement, Battery: passo 1, imagem 3 %32
    • Lay the laptop on a flat surface, bottom side up and slide the two battery release latches toward the outside of the case.
  2. HP Mini 311 RAM Replacement: passo 2, imagem 1 %32 HP Mini 311 RAM Replacement: passo 2, imagem 2 %32
    • Slide the battery away from the device to remove.
  3. HP Mini 311 RAM Replacement, Memory Shield: passo 3, imagem 1 %32
    • With the device still in a bottom side up position, proceed to unscrew the two 4.8mm Phillips 00 screws from the memory shield.
    • The screws will remain in the shied.
  4. HP Mini 311 RAM Replacement: passo 4, imagem 1 %32 HP Mini 311 RAM Replacement: passo 4, imagem 2 %32
    • Lift the memory shield up and remove from the laptop.
  5. HP Mini 311 RAM Replacement, RAM: passo 5, imagem 1 %32 HP Mini 311 RAM Replacement, RAM: passo 5, imagem 2 %32 HP Mini 311 RAM Replacement, RAM: passo 5, imagem 3 %32
    • Firmly press on the metal pins located on both sides of the RAM.
    • One side of the RAM will pop up to form a 40 degree angle with the body of the laptop.
    • Simply grab and remove the RAM from the device.
    The recommended battery goes directly to an iMac battery which is not compatible for the HP 311 Mini HP Mini 311 RAM Replacement
    Christine Fowler - Responder
Conclusão
Christian Santoyo
Membro desde: 01/31/13
495 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 20-4, Maness Winter 2013 Membro de Cal Poly, Team 20-4, Maness Winter 2013
CPSU-MANESS-W13S20G4
4 Membros
Autoria de 10 guias
2Comentários do guia
4 GB modules are not supported it seems.
You may see posts in the HP Support Forum saying that the Mini 311 will accept a 4 GB module. Possibly this is true for the Pavilion DM, but not the Mini 311.
The service manual says only 2GB or 1 GB are supported.
Other people posted that they tried a 4GB module and it did not work.
rafss - Responder
FYI, The link to buy the suggested part is wrong and not compatible.
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 3,755
