Ir para o conteúdo principal
HP Elite x2 1012 G2 Screen Replacement
Noah Stapp
Noah Stapp e 4 outros colaboradores
Última atualização em September 16, 2024
10 minutos
Moderado
Introdução
Ir para o passo 1
The screen is one of the most commonly damaged components of the HP Elite x2 1012 G2. Additionally, this guide is an important prerequisite to all other repairs on this device. Thankfully, removal and repair of the screen is relatively easy.
O que você precisa
Ferramentas
Exibir mais…
  1. HP Elite x2 1012 G2 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Make sure the device is turned off before starting.
    • Orient the device so the back is facing you, with the kickstand up.
  2. HP Elite x2 1012 G2 Screen Replacement: passo 2, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 2, imagem 2 %32 HP Elite x2 1012 G2 Screen Replacement: passo 2, imagem 3 %32
    • Remove the six 3mm Torx T5 screws underneath the kickstand.
  3. HP Elite x2 1012 G2 Screen Replacement: passo 3, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 3, imagem 2 %32
    • Turn the device over so the screen is facing you.
    • Place a suction cup firmly onto a corner of the screen.
    • Lift up gently until you see the screen separate from the casing.
    • Repeat this process for all four corners.
    • During reassembly, certain clips/edges may not snap into place properly even with a lot of force. To counteract this, lift the edge up, place the suction cup further inwards on the screen and pull it slightly upwards while pressing the edge of the screen downwards. The edge should snap correctly into the housing.
  4. HP Elite x2 1012 G2 Screen Replacement: passo 4, imagem 1 %32
    • Lift the screen up and off of the device.
    • Pry each corner up first, otherwise you may damage or crack the screen.
  5. HP Elite x2 1012 G2 Screen Replacement: passo 5, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 5, imagem 2 %32 HP Elite x2 1012 G2 Screen Replacement: passo 5, imagem 3 %32
    • Remove the two connectors on the back of the screen by lifting the connector tabs on the motherboard with a plastic opening tool and pulling gently.
  6. HP Elite x2 1012 G2 Screen Replacement: passo 6, imagem 1 %32 HP Elite x2 1012 G2 Screen Replacement: passo 6, imagem 2 %32
    • Remove the screen by gently lifting it off of the device.
Conclusão
4 outras pessoas executaram este guia.
Noah Stapp
Membro desde: 04/18/18
770 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G5, Livingston Spring 2018 Membro de Cal Poly, Team S18-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G5
4 Membros
Autoria de 13 guias
5Comentários do guia
Where can I purchase a screen for the HP Elite x2 1012 g2?
Greg M - Responder
just completed this, VERY surprising to find a HP product with an easy install
CILLIAN BYRNE - Responder
Just finished a repair and very easy to do. Thank you!!
Richard Taylor - Responder
The touch stopped working after the replacement. Any suggestions?
el._.msn - Responder
I replaced my screen and upon turning the device on I have a black screen. Already made sure connections are all attached correctly. Tried hard reset with power and volume button down for 15 seconds. A bad new screen? Any other ideas?
iamacomputertech - Responder
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 53
Últimos 30 dias: 141
Ao todo: 10,054
