Ir para o conteúdo principal
Game Boy Advance Shoulder Button and Side Panels Replacement
Aldo Corona
Aldo Corona e 7 outros colaboradores
Última atualização em 18 de set de 2024
5 - 10 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide for disassembly and for resolving jammed or finicky shoulder buttons.
O que você precisa
Ferramentas
Exibir mais…
  1. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 1 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 2 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: passo 1, imagem 3 %32
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: passo 2, imagem 1 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: passo 2, imagem 2 %32
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Back Panel: passo 3, imagem 1 %32
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: passo 4, imagem 1 %32 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: passo 4, imagem 2 %32
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - Responder
Conclusão
4 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Aldo Corona
Membro desde: 01/25/10
871 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 16-29, Maness Winter 2010 Membro de Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Membros
Autoria de 62 guias
1Comentário do guia
i need help th e side pannels loose
Mark - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 68
Ao todo: 8,810
