Ir para o conteúdo principal
Galaxy Book3 360 13" SSD Replacement
Dan
Dan e 2 outros colaboradores
Última atualização em February 16, 2024
25 minutos
Moderado
Guia colaborativo
Introdução
Ir para o passo 1
To replace the SSD you will need a Pry Tool and Phillips screw driver.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Galaxy Book3 360 13" SSD Replacement, Remove the Screws: passo 1, imagem 1 %32
    • Flip the laptop over and remove each rubber shoe
    • Use a Philips screwdriver to care fully remove each screw
  2. Galaxy Book3 360 13" SSD Replacement, Remove the Case: passo 2, imagem 1 %32 Galaxy Book3 360 13" SSD Replacement, Remove the Case: passo 2, imagem 2 %32
    • After removing the screws carefully pry open the case starting on the top right hinge.
    • There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
  3. Galaxy Book3 360 13" SSD Replacement, Replace the SSD: passo 3, imagem 1 %32
    • Carefully remove the screw holding down the SSD.
    • Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
    • Slide in your new SSD, and follow the previous steps in reverse.
Conclusão
5 outras pessoas executaram este guia.
Dan
Membro desde: 02/18/19
4.511 Reputação
Autoria de 9 guias
5Comentários do guia
Are you sure for the second slot it is 2280 and not 2230?
Jeremy Asher - Responder
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Galaxy book 3 360 15.6" inch variant support Gen 3 NVMe 2280 type ssd like WD Black SN770
Biswajit Shial -
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
I opened my Book3 Pro 360 5G and the SSD is covered by a metal shield. How do I remove this shield to gain access to the SSD and slot?
Lloyd Franklin - Responder
Comentar
Visualizações:
Últimas 24 horas: 10
Últimos 7 dias: 78
Últimos 30 dias: 361
Ao todo: 13,049
