Ir para o conteúdo principal
Fujifilm Finepix S1800 Top Cover Replacement
Ryan Rockford
Ryan Rockford e 6 outros colaboradores
Última atualização em January 5, 2024
25 - 30 minutos
Difícil
Precisa de mais images
Is the flash not flipping up on your Fujifilm Finepix S1800 camera? It might be time to replace the top cover plate. This guide will show you how to replace the top cover.
O que você precisa
Ferramentas
Exibir mais…
  1. Fujifilm Finepix S1800 Top Cover Replacement, Back Cover Assembly: passo 1, imagem 1 %32
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Top Cover Replacement: passo 2, imagem 1 %32
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Top Cover Replacement: passo 3, imagem 1 %32
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Top Cover Replacement: passo 4, imagem 1 %32 Fujifilm Finepix S1800 Top Cover Replacement: passo 4, imagem 2 %32
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: passo 5, imagem 1 %32 Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: passo 5, imagem 2 %32
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Finepix S1800 Top Cover Replacement: passo 6, imagem 1 %32
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Finepix S1800 Top Cover Replacement: passo 7, imagem 1 %32
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
  8. Fujifilm Finepix S1800 Top Cover Replacement, Top Cover: passo 8, imagem 1 %32
    • Lift the flash.
    • Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
  9. Fujifilm Finepix S1800 Top Cover Replacement: passo 9, imagem 1 %32 Fujifilm Finepix S1800 Top Cover Replacement: passo 9, imagem 2 %32
    • Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
  10. Fujifilm Finepix S1800 Top Cover Replacement: passo 10, imagem 1 %32 Fujifilm Finepix S1800 Top Cover Replacement: passo 10, imagem 2 %32
    • Switch the lever to disconnect the micro strip that connects the top plate.
    • Do not rip the micro strip.
  11. Fujifilm Finepix S1800 Top Cover Replacement: passo 11, imagem 1 %32
    • Remove the top cover.
Conclusão
Uma outra pessoa concluiu este guia.
Ryan Rockford
Membro desde: 02/15/17
618 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 8-6, Eyestone Spring 2017 Membro de USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
Membros da 4
Autoria de 10 guias
Um comentário
I had a problem with my Fuji Fine pix S 2950 (similar case) On / Off switch, this guide was invaluable to help me get into the top case moulding.
The fault was a crack around a solder pad were the SMT switch is mounted on the PCB , a simple solder job but an absolute bugger to get to.
Thank you for this simple and straight forward guide.
Bob Wilkins - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 705
