Fujifilm Finepix S1800 Top Cover Replacement
Introdução
Ir para o passo 1Is the flash not flipping up on your Fujifilm Finepix S1800 camera? It might be time to replace the top cover plate. This guide will show you how to replace the top cover.
O que você precisa
Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
Gently lift the back cover away from the device.
Lift the flash.
Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
Switch the lever to disconnect the micro strip that connects the top plate.
The second photo is after the top cover is removed. I’m repairing a s1600. The lens is stuck. But this guide and inside looks almost 100% the same as my s1600. Only thing is: i can’t remove the top cover. Removed all the same screws but the only difference is the lcd has no screws. Anyway the only screws I haven’t removed are the once inside the battery case (the 2 extra in the flash, not done here are also removed) Anyway the topcover looks stuck. And i’m going to try a plastic prying tool. The battery screws are very short. Maybe they are the problem but they look like they only hold the spring bumpers for battery. It must be difficult to put these bumpers back. But I must say I did 1. And the bumper is not falling out. So try those 3 screws first and then pry open the top.
Uma outra pessoa concluiu este guia.
Um comentário
I had a problem with my Fuji Fine pix S 2950 (similar case) On / Off switch, this guide was invaluable to help me get into the top case moulding.
The fault was a crack around a solder pad were the SMT switch is mounted on the PCB , a simple solder job but an absolute bugger to get to.
Thank you for this simple and straight forward guide.
