Ir para o conteúdo principal
Fujifilm FinePix Z1 LCD Screen Replacement
Carra
Carra e 2 outros colaboradores
Última atualização em May 4, 2020
55 minutos - 1 hora
Difícil
Precisa de mais images
Faltando Passos
Introdução
Ir para o passo 1
The LCD screen on the Fujifilm FinePix Z1 is durable but in unfortunate events can still be damaged. If the screen has had water damaged or has been cracked in some way, this guide will aid in removing the screen and replacing it with a new one.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, imagem 1 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, imagem 2 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, imagem 3 %32
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: passo 3, imagem 1 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 3, imagem 2 %32
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, imagem 1 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, imagem 2 %32 Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, imagem 3 %32
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
Conclusão
Carra
Membro desde: 01/30/18
533 Reputação
Autoria de 4 guias
Equipe
Baylor, Team S2-G4, Johnson Spring 2018 Membro de Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 22
Ao todo: 439
