Ir para o conteúdo principal
Fujifilm FinePix S4800 Motherboard Replacement
Fanessa Jeune
Fanessa Jeune e 4 outros colaboradores
Última atualização em May 7, 2024
45 minutos
Difícil
Introdução
Ir para o passo 1
In this guide, we will be taking apart the Fujifilm FinePix S4800 to remove and replace the motherboard . This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera. After removing the LCD screen, there awaits only a few more screws to detach from the RF shield and motherboard.
O que você precisa
Ferramentas
Exibir mais…
  1. Fujifilm FinePix S4800 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure that the camera is powered off before continuing.
    • Rotate the camera so that the label on the base of the camera is facing up.
    • On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
  2. Fujifilm FinePix S4800 Motherboard Replacement: passo 2, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 2, imagem 2 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 2, imagem 3 %32
    • Remove all four batteries and set them aside.
    • When replacing the batteries, be sure to note the markings on the face of the battery compartment. These markings let you know which side of the battery ("+" or "-") needs to be facing up in each slot.
  3. Fujifilm FinePix S4800 Motherboard Replacement, Rear Case: passo 3, imagem 1 %32
    • Remove the three 5.0 mm JIS #000 screws on the bottom of the camera.
  4. Fujifilm FinePix S4800 Motherboard Replacement: passo 4, imagem 1 %32
    • Rotate the camera so that the HDMI port is facing up.
    • Remove the two 5.0 mm JIS #000 screws.
  5. Fujifilm FinePix S4800 Motherboard Replacement: passo 5, imagem 1 %32
    • Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
  6. Fujifilm FinePix S4800 Motherboard Replacement: passo 6, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 6, imagem 2 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 6, imagem 3 %32
    • Press the pop-up button highlighted in the picture to release the flash mechanism.
    • Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
  7. Fujifilm FinePix S4800 Motherboard Replacement: passo 7, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 7, imagem 2 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
    • The plastic case is fragile, so take your time on each side making sure to pry each side evenly as you continue around the camera with the tool.
  8. Fujifilm FinePix S4800 Motherboard Replacement: passo 8, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 8, imagem 2 %32
    • Gently, remove the rear case from the camera and set it aside.
  9. Fujifilm FinePix S4800 Motherboard Replacement, LCD Screen: passo 9, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement, LCD Screen: passo 9, imagem 2 %32 Fujifilm FinePix S4800 Motherboard Replacement, LCD Screen: passo 9, imagem 3 %32
    • At this point, it is highly recommended that you wear an ESD wristband to prevent damage to the internal electronic components.
    • With respect to the camera that was disassembled for this guide, the LCD display easily fell out of its housing after the rear case was removed. If your screen fits more tightly, you can use a plastic removal tool to gently pry up one of the edges of the screen and that will release it from its mount.
    • Gently tilt the LCD screen toward the bottom of the camera and use a spudger to flip the lock for the ZIF cable attached to the LCD.
  10. Fujifilm FinePix S4800 Motherboard Replacement: passo 10, imagem 1 %32
    • Lift the screen away from the camera and set it aside.
  11. Fujifilm FinePix S4800 Motherboard Replacement, Electromagnetic Shield: passo 11, imagem 1 %32
    • Remove the four 4.5 mm JIS #000 screws.
    • The electromagnetic shield is attached onto the motherboard please proceed with caution when removing screws.
  12. Fujifilm FinePix S4800 Motherboard Replacement: passo 12, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 12, imagem 2 %32
    • Gently pull the shield off the motherboard and set it aside.
  13. Fujifilm FinePix S4800 Motherboard Replacement, Motherboard: passo 13, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement, Motherboard: passo 13, imagem 2 %32
    • When removing the screw attached to the motherboard, proceed slowly and apply only light pressure.
    • Remove the 4.5 mm JIS #000 screw.
  14. Fujifilm FinePix S4800 Motherboard Replacement: passo 14, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 14, imagem 2 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 14, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the electrical tape off the ZIF cable using tweezers.
    • Gently tilt the the lock for the ZIF cable attached to the motherboard with a plastic removal tool.
    • Pull the ZIF cable from motherboard using tweezers.
  15. Fujifilm FinePix S4800 Motherboard Replacement: passo 15, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 15, imagem 2 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 15, imagem 3 %32
  16. Fujifilm FinePix S4800 Motherboard Replacement: passo 16, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 16, imagem 2 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 16, imagem 3 %32
  17. Fujifilm FinePix S4800 Motherboard Replacement: passo 17, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 17, imagem 2 %32
    • There are two sections were wires are soldered onto the motherboard. There is also a third section were the motherboard and camera are soldered together. Please follow all safety precautions when desoldering.
    • In order to free the motherboard, detach the wires by desoldering.
    • Detach the soldering between the camera and motherboard by desoldering.
    • For instructions on desoldering see Como soldar e dessoldar contatos
  18. Fujifilm FinePix S4800 Motherboard Replacement: passo 18, imagem 1 %32 Fujifilm FinePix S4800 Motherboard Replacement: passo 18, imagem 2 %32
    • Gently pull the motherboard off and set it aside.
Conclusão
Uma outra pessoa concluiu este guia.
Fanessa Jeune
Membro desde: 02/17/17
303 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S19-G4, Hoffman Spring 2017 Membro de USF Tampa, Team S19-G4, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G4
4 Membros
Autoria de 16 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 17
Últimos 30 dias: 36
Ao todo: 1,481
