Fujifilm FinePix S4200 Motherboard Replacement
Introdução
Ir para o passo 1In this guide we will replace a Fujifilm FinePix S4200 motherboard.
The motherboard is a central part of any electrical system is connects all internal components and allows them to work together. When a motherboard fails It could cause many issues such as shutdowns, Connection errors, and reduced preformance.
You will need a Phillips #000 screwdriver and a Soldering Iron. Before using a Soldering Iron please consult the Soldering/desoldering connections guide.
O que você precisa
