Ir para o conteúdo principal
Foldable Grocery Cart Wheels Replacement
Saba Aafreen
Saba Aafreen e 2 outros colaboradores
Última atualização em May 29, 2024
45 minutos - 1 hora
Moderado
Introdução
Ir para o passo 1
If you have a foldable grocery cart or shopping trolly, that has its front wheels all worn out, then this guide will assist you in replacing the tattered wheels with new ones so you don’t have to worry about buying another cart. Damaged wheels of your grocery cart can cause your cart to not steer properly or even worse, collapse on the spot. It is important to replace them to avoid such situations and unnecessary expenses.
For the replacement, you can get an extra pair of wheels by buying new ones or use wheels that are in good condition from another cart that is not being used anymore. Just make sure that the wheels are of similar size to the old ones and that the hole is big enough to slide through the axle of the cart you’re currently using (some wheel sizes and center hole sizes may vary, so get a pair of wheels that are compatible with your grocery cart). Before starting, make sure your work area is open and free of any obstacles.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. Foldable Grocery Cart Wheels Replacement, Wheels: passo 1, imagem 1 %32 Foldable Grocery Cart Wheels Replacement, Wheels: passo 1, imagem 2 %32 Foldable Grocery Cart Wheels Replacement, Wheels: passo 1, imagem 3 %32
    • Using a large needle nose plier, take out the stoppers from each side of the axle.
    Hello, where can I find a axle rod for mini folding cart?
    Linda - Responder
    Hello, where can I find an replacement axle rod for my mini cart .
    Linda - Responder
    Hello, I've been raking my brain on the internet for a mini cart axle rod replacement. What internet or store sell them. Can you e mail me or call me #(334)412-6735 thank you
    Linda - Responder
    Hi I cannot do this I live alone and I really finding this hard to do is there an easier way
    Tracey hollanf - Responder
    My email is tracetholland16@gmail.com
  2. Foldable Grocery Cart Wheels Replacement: passo 2, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 2, imagem 2 %32
    • Use the large needle nose pliers to pull out the locking pins from the holes in the axel to detach the axel from the cart's legs.
    • Repeat for both sides.
  3. Foldable Grocery Cart Wheels Replacement: passo 3, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 3, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 3, imagem 3 %32
    • Carefully pull out the axle to detach it from the cart’s legs.
    • The washers and springs may fall out.
  4. Foldable Grocery Cart Wheels Replacement: passo 4, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 4, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 4, imagem 3 %32
    • Slide off the first washer, the spring, and the second washer.
  5. Foldable Grocery Cart Wheels Replacement: passo 5, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 5, imagem 2 %32
    • Take out the tattered wheel.
    • Make sure to keep the third washer on the axle.
    • Repeat steps 4 and 5 for the second wheel.
    Where can I find a 5 " wheel to fit that axel? Will it allow for a built in hub? I found a cart just like the one you are working on!!
    Jlynn Bell - Responder
    Sorry I was so unspecific. I'm in SF. COLES HARDWARE only carries 10" and up, and Lowe's is fun if you have all day to wander the store. I don't feel like gambling on AMAZON. I looked at Walmart, but some are over $20 a piece. That doesn't make sense to me. I guess we don't have a home Depot.
  6. Foldable Grocery Cart Wheels Replacement: passo 6, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 6, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 6, imagem 3 %32
    • Take one of the new wheels and slide it on one side of the axle.
  7. Foldable Grocery Cart Wheels Replacement: passo 7, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 7, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 7, imagem 3 %32
    • Slide on the first washer, the spring, and then the second washer back on the axle.
    • Repeat steps 6 and 7 for the second wheel.
  8. Foldable Grocery Cart Wheels Replacement: passo 8, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 8, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 8, imagem 3 %32
    • Carefully place the front wheel axle with the new wheels in the side holes of the cart’s legs.
  9. Foldable Grocery Cart Wheels Replacement: passo 9, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 9, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 9, imagem 3 %32
    • Insert the locking pins in each hole at both ends of the axle until the pins are halfway in the hole.
    • Using the hammer, tap the pins until they are entirely inside the hole.
    I just need the Locking pins. Is there specific item/size number for the lock pins? Where/How can these be purchased? Thank you for yourhelp.
    YSpiller - Responder
    Use Google and search for Locking Pin.
    Toon Konings -
  10. Foldable Grocery Cart Wheels Replacement: passo 10, imagem 1 %32 Foldable Grocery Cart Wheels Replacement: passo 10, imagem 2 %32 Foldable Grocery Cart Wheels Replacement: passo 10, imagem 3 %32
    • Lastly, push the stoppers in each hole of the cart's legs.
    • Using the hammer, tap them in place.
    How can I order the broken wheel for my shoppibg cart. I can send a picture via email. I can't upload the photo.
    Yolanda - Responder
Conclusão
Saba Aafreen
Membro desde: 06/30/21
232 Reputação
Autoria de 1 guia
2Comentários do guia
My back wheels need replacing. Can I use a different size because I’m having trouble finding the size I need. If they are a little bigger or smaller will it work. My wheels are non caster type wheels.
MoMac - Responder
Need to replace axle it's bent
Constance Butler - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 62
Últimos 30 dias: 248
Ao todo: 11,554
