Ir para o conteúdo principal
Dyson V8 Absolute Bin Replacement
Miranda Laberge
Miranda Laberge e 2 outros colaboradores
Última atualização em August 5, 2022
1 minuto
Fácil
Introdução
Ir para o passo 1
This guide will explain the process of removing the bin on the Dyson V8 Absolute. In the case of a broken or cracked bin, it is important to replace the bin for it to properly hold debris.
  1. Dyson V8 Absolute Bin Replacement, Bin: passo 1, imagem 1 %32
    • Set the device upright on a flat surface and detach the wand.
    • Pull the red bin release trigger, on top of the cyclone. This will require some force.
    I am unable to open the n. Red button is stuck shut. Is there another way to get it open?
    Helen Ruckman - Responder
    I have had the unit for quite a while and this is the first time it has been stuck shut.
    Every couple of months my bin sticks firmly and I am unable to open it. This has now required two return visits to the shop where I bought it, and still it happens regularly. For a top of the range Dyson which cost me around $900, it is disappointing. Vacuum is about 18 months old and very carefully looked after.
    Sorry this comment hasn’t helped your problem Helen, nor mine.
    Linda Lang - Responder
  2. Dyson V8 Absolute Bin Replacement: passo 2, imagem 1 %32 Dyson V8 Absolute Bin Replacement: passo 2, imagem 2 %32
    • Pull up on the latch until it's fully extend.
    • The bin will open to dispense debris once the red latch is pulled.
  3. Dyson V8 Absolute Bin Replacement: passo 3, imagem 1 %32 Dyson V8 Absolute Bin Replacement: passo 3, imagem 2 %32
    • Push the red circular button to release the latch on the cyclone.
    • The cyclone should release and be fully detached from the device.
  4. Dyson V8 Absolute Bin Replacement: passo 4, imagem 1 %32 Dyson V8 Absolute Bin Replacement: passo 4, imagem 2 %32
    • Push on the red release button on the bottom of the bin.
    • The bin should slide away from the handle.
    You didn't answer my question how to put bin cover back on bin. You just showed how to remove bin!!! That isn't the problem.
    Donna Madison - Responder
    You didn't answer my question how to attach bin lid which fell off. Please continue and include directions to attach the cover.
Conclusão
4 outras pessoas executaram este guia.
Miranda Laberge
Membro desde: 10/19/17
697 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team S1-G5, Rose Fall 2017 Membro de UW Tacoma, Team S1-G5, Rose Fall 2017
UWT-ROSE-F17S1G5
4 Membros
Autoria de 16 guias
2Comentários do guia
My bin seems to be more difficult to open all of the sudden and I have taken it all apart and put it back together. Still having the issue where the bin doesnt open when the cyclone pops up. HELP please
Rob Coughlin - Responder
I have a Dyson v8 and the red release button is stuck. What do I do.
Pamela Wanklyn - Responder
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 25
Últimos 30 dias: 115
Ao todo: 21,792
