Ir para o conteúdo principal
Desktop PC Front Fan Replacement
David Lennon
David Lennon e 4 outros colaboradores
Última atualização em December 24, 2023
10 - 15 minutos
Fácil
Introdução
Ir para o passo 1
Internal fans keep a computer at a stable temperature while operating. A faulty fan can cause a computer to overheat. It is important that all fans are in working order. Replacing a fan is an important skill for desktop PC users.
O que você precisa
Ferramentas
  1. Desktop PC Front Fan Replacement, Left Panel: passo 1, imagem 1 %32
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
    This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
    Dave Ellefson - Responder
    This is correct.
    DistroHopper39B -
  2. Desktop PC Front Fan Replacement: passo 2, imagem 1 %32 Desktop PC Front Fan Replacement: passo 2, imagem 2 %32
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Front Fan Replacement, Front Fan: passo 3, imagem 1 %32 Desktop PC Front Fan Replacement, Front Fan: passo 3, imagem 2 %32
    • Push to unlatch three grey connectors on the front panel.
  4. Desktop PC Front Fan Replacement: passo 4, imagem 1 %32
    • Disconnect the front panel from the computer face.
  5. Desktop PC Front Fan Replacement: passo 5, imagem 1 %32
    • Remove four Phillips #2 head, 5mm screws holding in the fan.
  6. Desktop PC Front Fan Replacement: passo 6, imagem 1 %32
    • Slide the fan out from the side of the casing.
  7. Desktop PC Front Fan Replacement: passo 7, imagem 1 %32
    • Disconnect the power cable from the fan.
Conclusão
39 outras pessoas executaram este guia.
David Lennon
Membro desde: 04/14/15
10.126 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 4-5, Maness Spring 2015 Membro de Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Membros
Autoria de 45 guias
1Comentário do guia
My two bottom connecters holding the face of my pc case have screws in them. Problem is that I can't fit a screw driver in the gaps to remove the screws! Any tips?
Jimmy Jam - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 36
Últimos 30 dias: 131
Ao todo: 29,211
