Ir para o conteúdo principal
Dell Precision 7560 Keyboard Replacement
Jack Allred
Jack Allred e 2 outros colaboradores
Última atualização em June 6, 2023
10 - 15 minutos
Moderado
Introdução
Ir para o passo 1
The guide shows how to remove the keyboard from a Dell Precision 7560. The keyboard is a core component of the computer, so keeping on top of its maintenance is vital. If the issue with the keyboard isn't merely debris keeping a key from functioning, then this guide will assist you in replacing the keyboard entirely.
O que você precisa
Ferramentas
Exibir mais…
  1. Dell Precision 7560 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Dell Precision 7560 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Dell Precision 7560 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Keyboard Replacement: passo 2, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 2, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 2, imagem 3 %32
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
    It is only 3 screws to remove the battery. Each one is labeled M2x5L on the tabs extending from the battery.
    Barry Todd - Responder
  3. Dell Precision 7560 Keyboard Replacement: passo 3, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 3, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 3, imagem 3 %32
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Dell Precision 7560 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • With the back cover and battery removed, locate the ribbon cables connected to the keyboard.
    • Pulling from the tab, carefully remove the connector.
  5. Dell Precision 7560 Keyboard Replacement: passo 5, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 5, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 5, imagem 3 %32
    • Turn the device over and open the screen to expose the keyboard.
    • Using an opener tool, pry along the edges of the keyboard to remove the keyboard's plate cover.
  6. Dell Precision 7560 Keyboard Replacement: passo 6, imagem 1 %32 Dell Precision 7560 Keyboard Replacement: passo 6, imagem 2 %32 Dell Precision 7560 Keyboard Replacement: passo 6, imagem 3 %32
    • With the plate cover removed, use the screwdriver to remove each of the six 2 mm screws.
    • Carefully remove the keyboard from the device.
    There is a 7th keyboard screw above and left of the “7/Home” key.
    MikeP - Responder
    There is one more screw between the [Backspace], [Num Lock], [\], [home] keys.
Conclusão
Jack Allred
Membro desde: 02/09/23
345 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
Guide is close, but not completely correct. Just need a little more attention to detail.
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 28
Ao todo: 1,104
