Ir para o conteúdo principal
Dell Precision 7560 Battery Replacement
Laisha
Laisha e 4 outros colaboradores
Última atualização em February 17, 2025
2 - 5 minutos
Moderado
Introdução
Ir para o passo 1
This guide covers how to replace the battery in a Dell Precison 7560. When replacing the battery, make sure to completely power off your device. Not doing so will cause a Fire Hazard. The battery is responsible for powering your device, so it is very hazardous.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. Dell Precision 7560 Battery Replacement, Battery: passo 1, imagem 1 %32 Dell Precision 7560 Battery Replacement, Battery: passo 1, imagem 2 %32 Dell Precision 7560 Battery Replacement, Battery: passo 1, imagem 3 %32
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Battery Replacement: passo 2, imagem 1 %32 Dell Precision 7560 Battery Replacement: passo 2, imagem 2 %32 Dell Precision 7560 Battery Replacement: passo 2, imagem 3 %32
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
    It is only 3 screws to remove the battery. Each one is labeled M2x5L on the tabs extending from the battery.
    Barry Todd - Responder
  3. Dell Precision 7560 Battery Replacement: passo 3, imagem 1 %32 Dell Precision 7560 Battery Replacement: passo 3, imagem 2 %32 Dell Precision 7560 Battery Replacement: passo 3, imagem 3 %32
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Laisha
Membro desde: 02/14/23
205 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
Was able to reset a battery that stopped charging with these instructions, appreciate it!
Emiline Doerr - Responder
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 25
Últimos 30 dias: 119
Ao todo: 2,512
