Ir para o conteúdo principal
Dell Latitude E4200 SSD Replacement
John Shellenberger
John Shellenberger e 2 outros colaboradores
Última atualização em June 22, 2015
5 minutos
Fácil
Introdução
Ir para o passo 1
Follow these steps in order to successfully replace the SSD of your laptop.
O que você precisa
Ferramentas
  1. Dell Latitude E4200 SSD Replacement, Back Panel: passo 1, imagem 1 %32
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 SSD Replacement: passo 2, imagem 1 %32 Dell Latitude E4200 SSD Replacement: passo 2, imagem 2 %32 Dell Latitude E4200 SSD Replacement: passo 2, imagem 3 %32
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 SSD Replacement: passo 3, imagem 1 %32
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 SSD Replacement, SSD: passo 4, imagem 1 %32
    • Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
    Où je puisse acheter ce composant ssd svp
    jose doss - Responder
  5. Dell Latitude E4200 SSD Replacement: passo 5, imagem 1 %32
    • Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
  6. Dell Latitude E4200 SSD Replacement: passo 6, imagem 1 %32
    • By applying pressure to the sides of the connector, pull the connector apart from the SSD.
Conclusão
6 outras pessoas executaram este guia.
Equipe
Baylor, Team 5-6, Williams Spring 2015 Membro de Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Membros
Autoria de 6 guias
1Comentário do guia
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/166263029472
jacques_06 - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 8,676
