Ir para o conteúdo principal
Dell Latitude 9410 2-in-1 SSD Replacement
Jessica Stephens
Jessica Stephens e 7 outros colaboradores
Última atualização em January 3, 2024
10 - 20 minutos
Moderado
Introdução
Ir para o passo 1
If you're finding many corrupted files or data, software incompatibility, hard drive errors, or an overall faulty SSD, then use this guide to replace the solid-state drive (SSD) of the Dell Latitude 9410 2-in-1. This guide should fix most file and incompatibility related issues on your laptop.
although, be sure to check the troubleshooting page before moving forward with replacement in case your problem is unrelated.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
  1. Dell Latitude 9410 2-in-1 SSD Replacement, Base Panel: passo 1, imagem 1 %32
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 SSD Replacement: passo 2, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 2, imagem 2 %32
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 SSD Replacement: passo 3, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 3, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 3, imagem 3 %32
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 SSD Replacement, SSD: passo 4, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: passo 4, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement, SSD: passo 4, imagem 3 %32
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 SSD Replacement: passo 5, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 5, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 5, imagem 3 %32
    • Use a Phillips #00 screwdriver to remove the 2 mm screw, loosening the bracket that covers the SSD.
    • Carefully lift the off the bracket.
    • The bracket is attached to the laptop and cannot be removed completely.
  6. Dell Latitude 9410 2-in-1 SSD Replacement: passo 6, imagem 1 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 6, imagem 2 %32 Dell Latitude 9410 2-in-1 SSD Replacement: passo 6, imagem 3 %32
    • Grip the SSD and pull directly backward until the SSD releases from its port.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 37
Ao todo: 1,278
