Ir para o conteúdo principal
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
Chase Sparkman
Chase Sparkman e 6 outros colaboradores
Última atualização em 1 de ago de 2024
5 minutos
Muito fácil
Precisa de melhores imagens
Introdução
Ir para o passo 1
The Memory Module (RAM) is one of the two memory storage places in your laptop. Some of your laptop's speed is dependent on the Memory Module so an upgrade may boost your laptop's overall performance if your current one if full.
O que você precisa
Ferramentas
Exibir mais…
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: passo 1, imagem 1 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: passo 1, imagem 2 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: passo 1, imagem 3 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 2, imagem 1 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 2, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 3, imagem 1 %32
    • Gently remove the battery from the rest of the device.
    In the official service manual, they also recommend the following after removing battery.:
    "Press and hold the power button for 5 seconds, to ground the system board."
    Jordan Lui - Responder
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): passo 4, imagem 1 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): passo 4, imagem 2 %32 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): passo 4, imagem 3 %32
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: passo 5, imagem 1 %32
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
Conclusão
4 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
4Comentários do guia
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - Responder
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - Responder
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - Responder
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 3,340
